05-16-2012, 10:54 AM | #1 |
Newbie Join Date: May 2012 Location: Plymouth, MI
| FX-R settings
Abody running an FX-R have some basic starting point setting for these other than the stock settings. Drag break Push control Current Reverse type |
05-16-2012, 11:42 AM | #2 |
| Re: FX-R settings
Drag brake and push are opposite of each other, you use one or the other but not both. Current limit is useful for fast starts on loose surfaces. Reverse is either off, instant or delayed. For crawling you may want 100% Drag brake (that means no Push). Current limiter is up to you, Off means full power to the wheels when starting. Crawlers usually use instant reverse. Go online and find out what each function does or, Heaven forbid, read the instruction sheet. |
05-16-2012, 12:24 PM | #3 |
| Re: FX-R settings
Thanks, I read the instruction sheet and since I am new to the crawlers I was just looking for some starting points from some of the more experienced people on this forum.
05-16-2012, 02:47 PM | #4 | |
| Re: FX-R settings Quote:
Join a club and do the comps, you'll really learn a lot. | |
FX-R settings - Similar Threads | ||||
CC Sidewinder - What settings? | topheavy | Electronics | 3 | 07-07-2010 05:27 PM |
Settings for PM's | HITMAN | Comments, Suggestions, and Help | 5 | 05-25-2010 10:12 PM |
esc settings | conrodss | Electronics | 1 | 05-21-2010 06:29 PM |
MM Settings | CreamLad | Electronics | 2 | 05-01-2008 12:34 PM |
DST settings | JEracing | Testing 1 2 3 | 0 | 03-20-2008 07:28 AM |
