05-17-2012, 07:58 PM | #1 |
Newbie Join Date: May 2012 Location: Cupertino
| Motor gets HOT!
hey Crawlers. having and Motor issue. Im running a 27T Motor w/ 14T Pinion 87T Spur. Castle ESC 3S .... my motor gets hot and i was wondering if i need to change the pinion/Spur ratio to a higher or lower tooth. thanks ! this is not a racer it is a crawler..
05-17-2012, 08:17 PM | #2 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: Motor gets HOT!
First, what vehicle, I'm guessing some sort of Axial RTR? What terrain are you running in, are you stalling the motor?
05-17-2012, 08:24 PM | #3 | |
| Re: Motor gets HOT! Quote:
Wraith Roller Full Drag brake Rocks/Trails Sidewinder ESC Last edited by isawul00k; 05-17-2012 at 08:37 PM. | |
05-17-2012, 08:42 PM | #4 |
| Re: Motor gets HOT!
You should go to a bigger spur. Too much load for a 27T motor. What motor? If it is a racing can motor it prolly has advanced timing, which, since this is a Wraith, I assume you are running backwards to make the Wraith go forward. If the motor is running backwards the timing is now retarded and the motor is working extra hard. |
05-17-2012, 09:23 PM | #5 | |
ya it is a race can. ok so can i advance the timing on the sidewinder? or should i get a new motor ? | |
05-17-2012, 09:34 PM | #6 |
| Re: Motor gets HOT! |
05-17-2012, 09:36 PM | #7 | |
Or if the endbell is screwed on you can just turn it to the zero timing mark. I don't think you can compensate with the ESC. | |
05-18-2012, 11:03 AM | #8 |
05-18-2012, 01:49 PM | #9 |
| Re: Motor gets HOT!
Counterclockwise for a regular vehicle and fixed timing cans. The wraith is clockwise looking at the pinion.
05-18-2012, 05:49 PM | #10 |
Motor gets HOT! - Similar Threads | ||||
How hot is too hot for the motor? | Mr. Ed | Losi Mini-Rock Crawler | 4 | 06-13-2010 11:09 PM |
motor temp - how hot is too hot? | wicked4x4 | Newbie General | 16 | 03-18-2010 09:49 AM |
motor getting hot | drawls88 | Team Losi Comp Crawler | 11 | 11-18-2009 07:03 PM |
I think i know why motor is so hot | loverichey | Team Losi Comp Crawler | 8 | 06-08-2009 06:29 PM |
Motor getting hot | wamf | Losi Mini-Rock Crawler | 6 | 06-05-2009 05:59 PM |
