05-22-2012, 07:59 AM | #1 |
Quarry Creeper Join Date: May 2009 Location: pacific NW
| Lipo low voltage...
I've got one battery probably only 6 total charges on it. went to charge it last night and my charger says "low voltage" and won't charge. Using iMax B6ac charger. Is there a way to save the battery? It won't charge it on any lipo setting, I've tried. Can I charge it on nimh or nicad for a few minutes just to try and get the voltage up? Sent from my PC36100 using Tapatalk 2 |
05-22-2012, 08:11 AM | #2 |
| Re: Lipo low voltage...
use the nimh setting and charge it for a couple minutes. then charge it as you normally would on lipo setting. it shocks the battery and may work. ive had to do it a couple times
05-22-2012, 08:27 AM | #3 |
On cheap lipo packs sometimes the cells do that....one will drop below LVC which is why I always set my cut off to be 3.3V/cell. That gives me just enough time when I head home to charge them back to Lipo Storage mode. Charging lipos that have dropped below LVC briefly 1-2 min in NiMH mode is not unheard of. Just make sure before charging you have it in a fireproof sack or somewhere that won't catch on fire. I had a brand new Gens Ace lipo come with the first cell below 3.0V which didn't allow me to charge it in Lipo mode so I had to bump charge it in NiMH mode for about a minute and a half before I could balance charge in Lipo mode. |
05-22-2012, 09:07 AM | #4 |
05-22-2012, 09:08 AM | #5 | |
Sent from my PC36100 using Tapatalk 2 | |
Lipo low voltage... - Similar Threads | ||||
Lipo low voltage alarm | newtoy | Electronics | 4 | 10-03-2011 11:46 AM |
lipo low voltage | Jay2380 | Electronics | 11 | 06-03-2010 11:17 AM |
Hyperion 606i low voltage after charging lipo | JRocker | Electronics | 2 | 06-16-2009 08:54 PM |
Removing low voltage shut-off circuit from LiPo | ComingApart | Electronics | 11 | 11-08-2007 07:13 PM |
lipo low voltage cutoffs?????? | jetboat | Electronics | 1 | 03-02-2007 09:19 AM |
