05-22-2012, 08:01 AM | #1 |
Newbie Join Date: Nov 2007 Location: Surprise
| What did I do?
Ok, I put a new motor in my scx10. Worked fine hooked up to the stock A-2 ESC. Put back in worked great around the house. Went out lastnight and when I gun it it doesn't move. I can see the pinion and spur move. but it move one tooth at a time. If I give it lite throtle it will start to go and then at that point i get punch it to full speed. from a dead stop I can't give it very much throtle forward or rev. new batts in rig and in TX. Any ideas? Is my ESC on it's last leg? Any help would be great. Thanks
05-22-2012, 10:20 AM | #2 |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
| Re: What did I do?
Are you using Lipo batteries or Nimh? It sounds like you just have a a dead battery and was hitting the low voltage cutoff. Marcus |
05-22-2012, 10:23 AM | #3 |
| Re: What did I do?
Using Nimh it had a fresh charge 2 nights ago when I swaped out the motor. Used to test for 3-5 min tops. Then back on the shelf till last night when the issue started.
05-24-2012, 01:57 AM | #4 |
Rock Crawler Join Date: May 2012 Location: Upland
| Re: What did I do?
Radio calibrate the esc
05-24-2012, 12:24 PM | #5 |
| Re: What did I do?
Thanks to you who posted. turns out i had some lose connections.
