05-23-2012, 05:19 PM | #1 |
Rock Crawler Join Date: Sep 2011 Location: Stanford
| What Voltage to run
I'm running dual hitec hs-645 servos on my Mad Torque super that i built, just wondering what to set bec at. If i set it at 6 volts do both servos see 6 volts each or do they only see 3 volts each. I know in a subwoofer set system if you have 1 sub seeing 600 watts and then hook another sub in then they both see 300 watts each, so does volts work the same way or not, any info would be nice, thanks.
05-23-2012, 06:10 PM | #2 |
They both see 6v so leave it where it is Sent from my iPad using Tapatalk |
05-24-2012, 01:53 AM | #3 |
Rock Crawler Join Date: May 2012 Location: Upland
| Re: What Voltage to run
Are you plugging each servo into a different outlet on the receiver?
05-24-2012, 05:22 AM | #4 |
With subs adding a second sub to one that sees 600 watts they will see 600 each or only 150, depending on series or parallel wiring. As long as the servos are wired in parallel they will both see six volts.
05-24-2012, 07:20 AM | #5 |
| Re: What Voltage to run |
05-24-2012, 09:35 AM | #6 |
Pebble Pounder Join Date: Mar 2012 Location: Madisonville
if they are wired together red to red black to black then they are wired parallel and both getting 6volts. If they are wired like this: (bec neg) to (servo 1 neg), (servo 1 pos) to (servo 2 neg), (servo 2 pos) to (bec pos) then they are wired in series and will both only get 3 volts. |
What Voltage to run - Similar Threads | ||||
2.2 scale Run for RC4x4 4th RUN | kenworthit | Scale Videos! | 2 | 09-09-2011 04:18 PM |
NEED INFO: High kV + Low Voltage 'vs' Low kV + High Voltage? | Chadworkz | Electronics | 9 | 01-28-2009 06:56 PM |
more voltage? | spinner | Electronics | 3 | 12-16-2008 05:01 PM |
