05-24-2012, 11:34 PM | #1 |
Rock Stacker Join Date: May 2012 Location: ks
| ae2 esc ?
how do i turn the lipo cut off, off.. want to run nimh whats the best way to do this with out castle link. thanks....
05-25-2012, 01:34 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Las Vegas 89121
| Re: ae2 esc ?
No need to change a thing, it will run NIMH as is. Its a pretty smart ESC.
05-25-2012, 02:33 PM | #3 |
| Re: ae2 esc ?
hmmm with lipo mode on? it will?
05-25-2012, 02:52 PM | #4 |
| Re: ae2 esc ?
Here's how to program if you don't have a Castle Link or Castle Field Programmer: http://castlecreations.com/support/d...s_ed_guide.pdf If you have the link plug it into laptop and configure, with card, set the red light to turn of auto LiPo to run the NIMH. |
05-25-2012, 08:00 PM | #5 |
| Re: ae2 esc ?
no link as said above guess i will just leave in in lipo mode
05-25-2012, 08:07 PM | #6 |
| Re: ae2 esc ? |
05-25-2012, 08:10 PM | #7 |
| Re: ae2 esc ?
Open the instructions above and start on page 20 to enter programming mode. Then change voltage cutoff information starts on page 29. You have to go through all the settings sequentially to program. It's not bad, just need to be patient and count beeps. if you're running NiMH then you'll want the LiPO cutoff turned off. When I ran my Castle ESC's on NiMH the packs didn't have enough punch and they kept cutting out and hitting the LVC. |
05-25-2012, 08:13 PM | #8 |
| Re: ae2 esc ?
Thanks Meatwad, the AE-2 is a little different than the OEM Castle's. Chazekxt, follow those instructions instead of what I posted above. Those instructions are for regular Castle controller where the AE-2 has less options. |
05-25-2012, 10:19 PM | #9 |
| Re: ae2 esc ?
thanks i will try . i put then nimh in and its cutting out real bad
06-24-2012, 06:41 PM | #10 |
| Re: ae2 esc ?
My AE-2 is going into LiPo shutdown, which is VERY annoying, I'm using it to control my winch. After reading through the instructions, I'm thinking that it will be worth the $25 to just get the Castle-Link.
06-24-2012, 07:54 PM | #11 |
| Re: ae2 esc ?
Manual programming isn't that bad, you just have to count and remember what number you're on.
06-24-2012, 09:48 PM | #12 |
| Re: ae2 esc ?
The AE-2 is not listed in the CastleLink software, which device do I use, the Sidewinder?
06-24-2012, 09:54 PM | #13 |
Pebble Pounder Join Date: Apr 2012 Location: McCalla
| Re: ae2 esc ?
when you pug into the castle link it automatically detects the ESC. I ordered a castle link for my rigs and two of them run the AE-2 and both are recognized by the castle link connection.
06-24-2012, 10:03 PM | #14 |
Rock Stacker Join Date: May 2012 Location: Boston
| Re: ae2 esc ?
the axial website has an instruction manual for the AE2. i used it to program the lipo cutoff and the drag brake down to 40% from the stock 100% which was crazy high. Nook66 posted this elsewhere on the rccrawler forum: I have worked out how to program some features of the AE-2 without using Castle Link. Like the Castle Creation SideWinder ESC, the standard way of getting into the programming mode is as follows. You may want to disconnect your motor from the ESC first to avoid the chance of a runaway. 1. Switch off the ESC 2. Switch on the transmitter and hold full throttle 3. Switch on the ESC 4. Release the throttle AFTER the second series of tones The ESC uses tones to indicate what Options you are currently accessing and its setting. eg. Option 2 setting 3 will be "beep-beep, pause, beep-beep-beep". You accept the setting for the option by engaging full throttle, or you can go to the next setting by engaging full reverse. Once you have configured the last option, the ESC will emit a series of tones and when that is finished the settings are stored. There are 3 Options available and here are the Settings available: Option 1 - LiPo CutOff (I think, please test first) Setting 1 - Off Setting 2 - On Option 2 - Drag Brake Setting 1 - Off Setting 2 to 6 - varying degree Option 3 - Brake/Reverse type Setting 1 - Forward-Brake-Reverse Setting 2 - Forward and Brake only Setting 3 - Forward and immediate reverse For a crawler using LiPo, the setting would be: 1-2 2-6 3-3 |
ae2 esc ? - Similar Threads | ||||
AE2 ESC issue | aircruiser | Electronics | 8 | 12-10-2011 11:34 AM |
ae2 esc | dracbec | Axial AX-10 Scorpion | 0 | 04-17-2011 11:40 AM |
