05-26-2012, 10:30 PM | #1 |
Rock Stacker Join Date: Feb 2012 Location: Flinthills
| AX-3 not binding to rx
To put it simply, I am an ignorant when it comes to electronics, so I am aking for some help. I have hit the search button for a few hours and still can't find an answer. The stock servo on my Wraith got submerged. Wasn't to worried cause I had covered it with liquid tape, but I think it still got wet inside 'cause about 5 minutes later I had all sorts of glitches in the controls. I noticed that the connector on the red wire from the battery was darkened and the truck stuttered in forward and reverse and wouldn't steer. I figured the servo was trash. Replaced it with a new HS7954 and I had nothing but red LEDs flashing and a constant "searching" beep. I tried binding the tx and rx 5 times. I had another battery that I was using, not the "damaged" one and I have replaced the batteries in the tx. All electronics are stock except the servo. Would the esc cause this problem if it was damaged, electrically, when the servo was submerged? |
AX-3 not binding to rx - Similar Threads | ||||
binding, i think | blasterracer817 | Losi Micro-Rock Crawler | 6 | 03-03-2011 02:17 PM |
binding? | azrcr | Electronics | 1 | 06-04-2010 01:29 AM |
binding???? | KrawlerKing | Team Losi Comp Crawler | 4 | 12-30-2009 09:37 AM |
Binding?'s | Straightjacket | Losi Mini-Rock Crawler | 4 | 10-01-2009 06:20 PM |
binding | Drvnbeing | Electronics | 3 | 03-31-2009 04:48 PM |
