05-28-2012, 12:40 PM | #1 |
Newbie Join Date: Mar 2007 Location: spanaway
| ae 2.4 servo plug?
Anyone know the servo plug config on the ae electronics/futaba/spectrum/JR.
05-28-2012, 12:53 PM | #2 |
Pebble Pounder Join Date: Mar 2012 Location: Madisonville
| Re: ae 2.4 servo plug?
Are you talking about a bind plug?
05-28-2012, 01:03 PM | #3 |
Or are you talking about which wire is what? If that is your question they are usually marked on the receiver it will be really small and barely noticeable, you will have - + S negative positive signal it will always be s + - or - + s positive will always be in the middle. To bind all you do is ground the signal, or connect the s and the - together. Last edited by mahgninnuc1; 05-28-2012 at 01:06 PM. |
05-28-2012, 01:06 PM | #4 |
If you are talking about coloring of the wires.... Brown - Red + Orange s or black - Red + white S
05-28-2012, 01:59 PM | #5 | |
Newbie Join Date: May 2012 Location: india
| Re: ae 2.4 servo plug? Quote:
I did not understand your question but I gives some information about these sevo.JR,Futaba,Spectrum servos are good brands. but not all of their models are equal in quality. The following are some of the basics I use when choosing which servo. At least staying with good brand names will provide you with a servo that should center well but don't forget to also consider the other specs that are also important. | |
05-28-2012, 03:59 PM | #6 |
| Re: ae 2.4 servo plug? |
05-28-2012, 07:02 PM | #7 |
Thank everyone you guy rock that's what I needed. I have a ae rec and wanted to make shure the esc plug was right. Looks like the rec is toast Sent from my ADR6400L using Tapatalk 2 |
ae 2.4 servo plug? - Similar Threads | ||||
Tapping into 3s balance plug for servo power | ik632 | Electronics | 3 | 01-26-2012 06:21 PM |
Servo and ESC RX plug interest? | Chris_The_Battery_Man | Electronics | 18 | 10-27-2011 01:35 AM |
Got a trick for getting a servo plug in and out easy,, | grouser | Electronics | 11 | 06-24-2009 08:26 AM |
transfer case, servo & esc plug questions | pantablo | Losi Mini-Rock Crawler | 11 | 05-23-2009 09:06 PM |
spectrum reciever - which way to plug in esc / servo | knuckleslammer | Newbie General | 2 | 04-16-2009 07:01 PM |
