05-28-2012, 09:22 PM | #1 |
Pebble Pounder Join Date: Feb 2010 Location: Rapid City
| submerged foff
This weekend I thought that it would be cool to try water-skipping the foff. First time I tried it with a 6 cell stick pack. That went fairly well considering the weight of the batt. I knew it could do better. After I got back home and put my new 3s on the charger, I checked for water in my radio box. Everything was dry, even the ballooned batt. Second attempt with 3s....WOW, what a difference. All was well until it turned a bit and hooked a wheel(really on water???), and that was that. Retrieved it and immediately unplugged the batt. Pulled the body, found a slightly puffy lipo. Opened the radio box anbd found it about 1/3 full of water. Removed everything and took the receiver and esc apart. The rx still works and the esc tries to, but it only turns the motor slow and choppy and it gets warm quick. Is the lipo junk? How about the esc? |
05-28-2012, 09:30 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: gervais
Probably shouldn't have tested it right away, you probably junked them. Next and if you still want to try, bury them in rice and let them sit for a few days, the rice will suck all the moisture out
05-28-2012, 09:32 PM | #3 |
| Re: submerged foff
I did use canned air to dry them off best that I could and let them sit for about 2 hours before reassembling and trying them.
05-28-2012, 09:38 PM | #4 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
| Re: submerged foff
You should have let them dry much longer. Puttting them in rice is best.
05-28-2012, 09:42 PM | #5 |
| Re: submerged foff
Seems like having rice around could be a bit handy. Can the affected parts remain intact for the rice treatment? |
05-28-2012, 09:59 PM | #6 |
| Re: submerged foff
I would take them out of their cases first.
05-28-2012, 10:52 PM | #7 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
| Re: submerged foff
Take them apart and let dry for a day or so.. And Or throw the electronics into rice as suggested.. Then turf the lipo and try again!! Im going to be itll be fine
05-28-2012, 10:59 PM | #8 |
| Re: submerged foff |
05-28-2012, 11:24 PM | #9 |
Pebble Pounder Join Date: Dec 2010 Location: Elk Grove
06-04-2012, 01:13 PM | #10 |
| Re: update
After 48 hours in rice we still have failure of esc.
submerged foff - Similar Threads | ||||
Motor cuts in and out when submerged? | dolphenwulf | Electronics | 4 | 09-08-2011 06:08 AM |
submerged FX-R, how bad can it be? | brokeitagain | Electronics | 10 | 06-14-2009 11:17 PM |
submerged crawler | rockdog1 | Chit Chat | 15 | 02-08-2008 06:42 PM |
submerged Lipo's | jetboat | Electronics | 7 | 03-27-2007 10:57 AM |
