05-29-2012, 03:17 PM | #1 |
| balancer adapter for the thunder ac 6 charger?
where can i get a lipo adapter, my friend lost the one that comes with the charger and i don't see it listed in hobbypartz.
05-29-2012, 03:21 PM | #2 |
| Re: balancer adapter for the thunder ac 6 charger? |
05-29-2012, 03:24 PM | #3 |
Thanks Jeremy, but i am looking for the adapter for the lipos that is included with the charger, 2s-6s
05-29-2012, 03:27 PM | #4 |
Yeah, that should just be a 6S balancer plug, right? This is what you are looking for, correct: ? |
05-29-2012, 03:27 PM | #5 |
Check the pic above, or something like what you have pictured
05-29-2012, 03:32 PM | #6 |
05-29-2012, 03:36 PM | #7 |
That is just the cable, i need the whole thing Edit, balance board , i think its called |
05-29-2012, 04:00 PM | #8 |
Found the adapter's page, now which one is the same as the one on the thunder adapter? Balance Adapters - A Main Hobbies |
05-29-2012, 04:05 PM | #9 |
Ahh...ok....I thought you just needed the cable. From this pic on the HobbyPartz website, it looks like it uses a JST/XH balancer board (which, IIRC is the same as Align): http://ep.yimg.com/ca/I/yhst-6219634..._2212_43365680 What batteries is he charging? |
05-29-2012, 04:06 PM | #10 |
hobbypartz gens and sky lipos
05-29-2012, 04:08 PM | #11 |
look like jst/hx as per their site
05-29-2012, 04:09 PM | #12 |
Yep....the Gens Ace use JST/XH: Hitec X4 Balancing Adapter (XH) [HRC44155] | Electric Accessories - A Main Hobbies |
05-29-2012, 04:11 PM | #13 |
thanks buddy |
05-29-2012, 04:19 PM | #14 |
Pebble Pounder Join Date: Jan 2010 Location: League City
EDIT: As a note, the battery balance connector uses an Align/JST-XH type connector. So that (HX) should be your connector type on your charger, the battery end is whatever battery balance connector you have.....
05-29-2012, 04:21 PM | #15 |
I type too slow, what Jeremy said........
05-29-2012, 04:23 PM | #16 |
05-29-2012, 07:08 PM | #17 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
I have the Hitec X4 and all I do is plug the battery right into the charger. I don't even bother with those boards that came with it. Negative to the far right and it balances them fine. The AC6 has built in balancing so it should work for you that way. I just had to trim a bit off my balance plug on the battery for it to fit correct.
05-29-2012, 07:23 PM | #18 | |
| Re: balancer adapter for the thunder ac 6 charger? Quote:
If you wear out a balance board, it's cheap to replace. If you wear out/damage the charger port, it's a lot harder to fix. | |
05-30-2012, 12:12 PM | #19 | |
balancer adapter for the thunder ac 6 charger? - Similar Threads | ||||
need help finding a balancer adapter for ac6 | klabeaume | Electronics | 6 | 05-01-2010 03:20 PM |
Hyperion charger and making your own balancer adapter | John | Electronics | 3 | 07-06-2009 04:11 PM |
Thunder Power LIPO balancer adapter??? | BarCrawl | Electronics | 2 | 05-25-2009 03:51 PM |
Will my balancer work with this battery? or will I need an adapter? | BigB_117 | Electronics | 2 | 03-09-2009 09:25 PM |
Thunder power balancer | hotwheels000 | Electronics | 2 | 05-13-2007 01:17 PM |
