05-31-2012, 09:47 PM | #1 |
Newbie Join Date: Oct 2009 Location: brentwood
| need help with my hh torque master brxl
ok i have a question for u guys. i baught a waterproof hh brxl for scale rig. i installed it and ran a few batts through it and i put it on the chelf for about six months. i pulled it off the shelf and put a fresh batt in it and when i turned it on it didnt drive or reverse... i first that it had a bad connection to the motor but all wires are good, im getting power to the servo and all of the l.e.d.'s work like the throttle is working but ... no power to the motor... and it doesnt do the little castle beep sequence when i plug it in... do you guys hav any advice??? |
05-31-2012, 09:53 PM | #2 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: need help with my hh torque master brxl
Make sure your radio adjustments are neutral. Might need to recalibrate to the radio?
05-31-2012, 10:06 PM | #3 |
Try swapping out motors first. Do you get tones from the motor? All else fails, send her in and I can check it out.
06-01-2012, 12:02 PM | #4 |
thanks rob ill try swapping out motors. ill msg u if that doesnt work!
need help with my hh torque master brxl - Similar Threads | ||||
torque master ? | volvroom | Losi Mini-Rock Crawler | 1 | 07-28-2010 10:55 PM |
torque master? | acs1414 | Electronics | 1 | 03-18-2010 01:14 PM |
My HH torque master | Drvnbeing | Losi Mini-Rock Crawler | 9 | 05-01-2009 11:44 AM |
torque master | jason yates | Losi Mini-Rock Crawler | 8 | 10-30-2008 05:15 PM |
