06-02-2012, 09:52 AM | #1 |
Rock Crawler Join Date: Mar 2009 Location: East TN
| Is Spectrum where it's at?
I have a Futaba 3PM and am tired of the non 2.4 lifestyle with this crawler. I woud like to switch to a DX3C but want to make sure it can do the stuff I need it to. I'm very specific on my 4 wheel steer. Question: On the 3PM, I can switch it on the 2 position 3rd ch. to 4ws. I can press another buttom to be rear steer only while 4ws is one. I can adjust a trim during rear steer and have crab steer. Can the DX3C do this as easily or easier? I assume so, but want to be sure considering i have not owned a Spectrum. Thanks |
06-02-2012, 10:26 AM | #2 |
| Re: Is Spectrum where it's at?
No, none of the Spektrum radios can do that... you can get similar to that on a hacked gt3b though. but it be a 3 position so left is front only, midddle is 4ws, and right is rear only. Then you can assign another switch to turn crab on/off....also on the 3 way, you can set it up to be a smaller step than 100, and at the values inbetween -100,0,100 it is a bias mix so one servo or the other will only turn a percentage of the other. |
06-02-2012, 10:37 AM | #3 |
gt3b was my other thought.I've thought about getting a prehacked one. the downfall is it just doesnt seem to have the same support if there is a problem with it.
06-02-2012, 10:47 AM | #4 |
I wonder (and wish it had) why the acoms 4ch never caught with crawler crowd? granted when i bought mine about 6 years ago it was only available in fm 40mhz freq. which i think isn't legal in the u.s. , but even after, there was a 2.4 version. the 3rd and 4th channels are -100 0 100 and fully adjustable epa's, so you could have dig, 4ws, crab and anything in between, i still have mine in the fm version, to bad it's a pia to get extra receivers, it was about $99 back then with 3 standars servos, this is the only radio i use for my supers now, although i own dx3r and gtb3, they don't hold a candle to this older radio IMHO |
06-02-2012, 11:01 AM | #5 | |
| Re: Is Spectrum where it's at? Quote:
1-The "hacker" already replied to this thread. 2-There is a thread here JUST FOR the GT3B. 3-There are templates for quite a few set-ups, plenty of people to ask if you run into an issue. 4-Last, but not least, LosiKid will work with you "IF" you even have an issue. | |
06-02-2012, 11:09 AM | #6 | |
06-02-2012, 11:30 AM | #7 | |
Also if he really wanted it to work that way, it wouldn't be hard to add it to the next fw release | |
06-02-2012, 11:42 AM | #8 | ||
GT3B Hack Question and Answer Thread 1626 posts in that thread, and 568 of them are mine, and abunch of my replies answer more than one question...plus i easily spend 2 hours or so everyday answering pms and emails Quote:
2. 3. Yea, i need to make more templates, but if the ones i have don't work for someones setup, i will right a new one 4. Yes, as long as it was hacked by me or hacked with my products, i'll fix it at price of parts, If the issue was because of me, i'll fix it for free...i've also sent out quite afew free mods if someone messed theres up while trying to install them, and i've installed stuff for free before as well if the customer couldn't figure it out or messed something up. | ||
06-02-2012, 12:09 PM | #9 |
Rock Crawler Join Date: Nov 2009 Location: poteau
well when i had 4ws on my wraith (and the dx3c) it worked something like you mentioned. i used the 3 position 3rd channel to control the 4ws. one way turn right, center was center, other way turn left. then i uesed the 4ws mix to either have the rear work the same direction as the front, or opposite the front. now if you leave the 4ws mix screen up on the display while you are driving you can use your thumb to turn the mix off and use the 3 position switch to turn the back manuallly, once you center the rear you can use your thumb to turn the mix back on. not ideal but worked. personally i would skip the dx3c and go with either the futaba 4pl or the flysky. |
06-02-2012, 02:09 PM | #10 |
these are some good points. I guess I'll be looking more into the flysky. I like my futaba 3pm but it twitches bad and seems to not get a good signal. I'm thinkin that the reciever is going bad? Also, which it shouldnt matter, the 3pl is ungly. Also, I've read it cant be programed the same as the 3pm.
06-02-2012, 06:28 PM | #11 |
Futaba is probably the best radio system out there. Is you have the $$ look at the 4Pl or 4pks. If your not that rich, the flysky is a great option
06-02-2012, 06:53 PM | #12 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
After using many Spektrum radio's I finally dropped the $200.00 and got the 4PL and it's a totaly new experiance . I do know that there are quite a few that have Losikid's radio too, and it seems real good, I just have'nt had one. |
06-03-2012, 04:03 PM | #13 |
Do you think the reciever going bad is why mine might be so twitchy or is it just time for a new radio. It used to not be so bad.
06-03-2012, 04:15 PM | #14 |
| Re: Is Spectrum where it's at? |
Is Spectrum where it's at? - Similar Threads | ||||
Spectrum dsm | R1Buggy | G-Made Crawlers | 2 | 01-20-2012 12:31 AM |
Spectrum DX5E | PileDriver | Electronics | 0 | 05-20-2010 07:00 PM |
