12-25-2004, 12:56 AM | #21 |
Pebble Pounder Join Date: May 2004 Location: east coast
| Re: Glitchy Glitcherson
still glitching? matt |
12-25-2004, 02:04 PM | #22 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: Glitchy Glitcherson Bruiser/Mountaineer onwers HELP!
Still glitchy. I am looking for a static bag to try that. I am really tired of working on it right now, I spent way too much time on it in the last couple of days. I got so frustrated with it that I slammed my fists down on it, good think it is steel. I am taking a break from it for it's own safety! 8O |
12-25-2004, 04:45 PM | #23 |
Rock Crawler Join Date: Aug 2004 Location: Concord Ca
| Re: Glitchy Glitcherson (Bruiser/Mountaineer owners HELP)
Badger did you disable the BEC and install a reciever pack? Sounds like low voltage at a distance. With three chanels working you may need to use 5 cell reciever pack and no BEC.
12-25-2004, 09:36 PM | #24 | |
Rock Crawler Join Date: Nov 2004 Location: roanoke
| Re: Glitchy Glitcherson Bruiser/Mountaineer onwers HELP! Quote:
im guessing you have some metal to metal rubbing, seeing as how everything is steel. from your description it sounds like it happens at speed? id say something is rubbing/vibrating/scraping/etc something else. i recommend covering any linkages with heat shrink to keep them from rubbing also check for loose screws or worn parts. wouldnt hurt to check all your wiring, a tiny hole in a servo wire can drive you nuts. if nothing fixes it, i think that dissasembly and cleaning is in order, then grease everything up. sad to hear you are having problems i wish you luck. | |
12-25-2004, 11:02 PM | #25 | ||
I will figure it out, I have great trouble shooting skills (working on computers for so long) and have not touched it in two days so I will go back at it tonight and tomorrow morning. I know the electronics are all good because I tested them all in my TXT. | ||
12-31-2004, 04:48 PM | #26 |
Newbie Join Date: Dec 2004
another shot in the dark but has happened to me b4, if u have a xtra set of xtals try them i had this same issue with a vector once (low to the ground and a bumpy ride) and when i moved rx, servos, and pack to nitro quake (big tires/shocks so a nice smooth ride) it would work fine, it turned out the the vibration in the vector was causeing the issues (beleave it or not xtals can and will go bad from too many wrecks at high speed or cat knocking them off the table when changing rx's )
12-31-2004, 05:27 PM | #27 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
Here is my favorite trick (since I suffer from sooooooooo much twitching..) Get the rig w/ a full battery, including your radio batts. Go somewhere with ABSOLUTE total darkness, with the body off. Run the piss out of it and watch if it arcs anywhere. As we all know, the motors usually do, but only worry if that is in synch with the twitching. I've caught a few things this way. I've also learned that running a reciever pack helps a lot. So does running good, new motors. My other downfall has been not fully charged batts in the radio. |
01-02-2005, 06:28 PM | #28 |
So?! Any luck?
01-03-2005, 10:27 AM | #29 |
Newbie Join Date: Apr 2004 Location: Perth Westren Australia
hey badger ive just been having a look at your pics and i notice that u have a cap soldered betwen +ve and -ve on your motor and one other cap half soldered onto the +ve termianl. correct me if im wrong but arent caps meant to be soldered from the +ve terminal to the can and from the -ve terminal to the can. this way brush arc in the motor is suppessed and prevents glitching? just a thought thats all as i had a similar problem with an ally chassis rc10 and it turned out i had broken a leg off the cap due to vibration. Hope this helps!! |
01-03-2005, 11:57 AM | #30 |
fortressbeast - I know it's not the xtals, because my transmitter is synthesized and I have put the receiver in my TXT which worked fine. I have also installed my novak synthesized receiver in the Mounty and it still had problems. SR5Dave - Yeah the motor is the only thing that arcs when it twitches. It is definitly the motor/tranny combo causing the problems. I have swapped them out for two other motor/tranny's and it still has the problem. Lucus - You are correct, I over looked that and when I brought it down to the LHS he noticed it as well, so I corrected it hoping for the best and nothing. I have a solution though.... I took the pile-o-metal they call a motor/tranny out and am going to install a Pede tranny and Lathe motor. No I really took it out because they just weigh too much and are soo large. Here's what I did with the extra space up front where the motor was. The Pede tranny and battery pack are going in the middle of the chassis. Thanks for all the help guys! |
01-03-2005, 12:30 PM | #31 |
one last question badger u know those crappy little green fibre discs that tamiya give u to mount between the motor and motor plate? are u meant to originally have one of those in there?
01-03-2005, 01:07 PM | #32 | |
| Re: Glitchy Glitcherson (Bruiser/Mountaineer owners HELP) Quote:
