12-24-2004, 01:00 PM | #1 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Glitchy Glitcherson (Bruiser/Mountaineer owners HELP)
Pull up a chair, this is going to be long... I am about to though the Mountaineer AWAY! I cannot get this POS to stop glitching. It glitches so bad that it is not even fun to drive and I am worried that I might strip gears from it jolting from forward to reverse so hard and fast. It does not glitch at very little throttle but when I give it more throttle it goes crazy. It has the following electronics: Rooster Futaba R123F 75 Mhz micro receiver Steering servo Hitec HS5625MG Shifting servo Hitec HS303 6 cell stick pack 6v rx pack. Hitec Links 3D synthesized controller Deans connectors every where What I have done: 1.I have mounted the receiver in every location I can think of on the truck 2. Located the ESC in many spots 3. Swapped the stock 750 motor for a different stock 750 motor (good thing I still have the other 2 mountaineers at my house ) 4. Replaced the capacitors on the motor, it has 3 total. 5. Used different batteries 6. Swapped the Rooster for a Super Rooster 7. Swapped the Futaba receiver for a Novak synthesized receiver 8. Unplugged the servos from the receiver None of these changes made any difference at all. These changes did help :? 1. Hooked up a 750 motor (not installed in the truck, just loose on my bench) and no glitching :? 2. Pulled all the electronics out of the truck and hooked them up, no glitching. :? 3. Hooked up a 540 motor (not installed in the truck, just loose on my bench) and no glitching :? 4. Put the ESC/Receiver (Rooster/Futaba) in my TXT and no glitching at all. :? I noticed when it glitches the ESC light flickers, and If I disconnect the motor wires the ESC does not flicker at all when going through the throttle cycle. I am begining to think this chassis/motor/tranny config is the problem. I have spent AT LEAST 6 hours trying to get rid of the glitching. I am done for now, I don't even want to look at the truck! Here are some pics of the latest electronics config. |
12-24-2004, 01:08 PM | #2 |
Pebble Pounder Join Date: May 2004 Location: east coast
| Re: Glitchy Glitcherson
i had the saem problum with my tlt! take some electrical tape and put them over the capitors cause they might be touching other metal and might be making aother connection ii did that and it stoped glitching!! also if that doesnt work i would really like to have that truck matt |
12-24-2004, 01:13 PM | #3 | |
| Re: Glitchy Glitcherson Quote:
12-24-2004, 01:21 PM | #4 |
like on the motor! it can never hurt to try is it? matt |
12-24-2004, 01:26 PM | #5 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I had same problem on my TXT. Try slipping a small length of fuel line over antenna wire, from base of antenna tube to reciever. Combination of that and moving my reciever to a plastic mount, from an alum mount, fixed my problem. Looks like yours is already mounted to plastic. My esc light also flickered when I was having problems. |
12-24-2004, 04:04 PM | #6 | |
No I am not going to get rid of the truck just because it is having this problem. I will figure it out eventually. :? | |
12-24-2004, 04:10 PM | #7 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
That tranny seems to have been cleaned, are the tranny gears lubed/greased at all? There's a bunch of moving metal-on-metal in that tranny... |
12-24-2004, 05:24 PM | #8 |
well IF you dont figure it out, could i take it off your hands?? matt |
12-24-2004, 05:30 PM | #9 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
Badger did you try reseting the esc. If you have the bottom plate try putting that on. did you try leaving the servos and motor in the car but having the rx and esc off of it? are the servos glitching too or only the esc? :? |
12-24-2004, 05:33 PM | #10 | |
Shiiit! You honestly think I am going to sell this truck just because it glitches? If I cannot figure out where the glitch is coming from I'l just glitch this F'ing truck over the rocks! | |
12-24-2004, 05:37 PM | #11 |
my friend had a t2 that had a metal chassis and it glitched all the time but when we put his rx in a anti static bag it stoped glitching and he cried. |
12-24-2004, 05:50 PM | #12 |
damnnnn would that be with or with out electronics? cause i might get it!! matt |
12-24-2004, 06:04 PM | #13 | |
Crawler - Yes it would come with ALL my electronic and my TXT. | |
12-24-2004, 06:05 PM | #14 |
no cause i would really consider buying it matt |
12-24-2004, 06:53 PM | #15 | |
12-24-2004, 07:37 PM | #16 |
OMG he hasn't a clue |
12-24-2004, 07:46 PM | #17 |
yeah i do! im just too tired to relize it matt |
12-24-2004, 08:23 PM | #18 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
Pull the motor out, turn the radio gear on and give it a shove. If it glitches, it's something in the axles or tranny. Disconnect the driveshafts and do it again. This way you should be able to narrow it down. It does sound like a lack of lube aand metal rubbing together.
12-24-2004, 11:52 PM | #19 | |
And as far as shoving it, I don't think that would work. It does not glitch at very low speeds so I would have to pretty much huck it down my street. Then I won't be close enough to see if it glitches. :? Maybe I could get bigred to ride it down the street and let me know if it glitches? | |
12-25-2004, 12:04 AM | #20 |
Dude its still glitching did you try any thing new. you think you can get done for the ttc. i still have to build my rig. |
