06-03-2012, 11:17 AM | #1 |
Rock Crawler Join Date: May 2009 Location: 354
| 1/10 and 1/8 bl motor.
will the screw holes line up the same, so if I decided to go 1/8 bl motor I don't have to change the motor mount? any info would be great. |
06-03-2012, 04:09 PM | #2 |
Rock Stacker Join Date: Aug 2011 Location: Canada
| Re: 1/10 and 1/8 bl motor.
In general, most 1/8th motors share the same bolt circle diameter as a 540 can and will bolt up to a 540 size mount provided there is room for the motor to fit. You may need a larger diameter screw, but that depends on the manufacturer of the motor. |
06-03-2012, 07:20 PM | #3 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Like above, they pretty much use a 25mm motor mount with 3mm screws.
06-03-2012, 08:39 PM | #4 |
awesome, thanks guys |
1/10 and 1/8 bl motor. - Similar Threads | ||||
which motor novak 55t motor or integy v10 professinal 75t | hpiontherocks | HPI Wheely King | 0 | 08-04-2008 03:36 PM |
