06-06-2012, 06:41 PM | #1 |
Rock Crawler Join Date: May 2011 Location: SoCal
| FlySky troubleshooting
Trying to help a friend who's having a problem with his AX10 / GT3B. The rig has suddently taken to severe chattering with reverse motion. Everything else seems to work okay. Swapping out all the electronics, one at a time, revealed that returning to his Axial RTR AX1 transmitter makes the problem go away. It's not likely the FlySky RX, because he substituted spares. Seems like the transmitter must be the culprit, but we don't know if it's defective or if the programming could have gotten screwed up. Reversed channel 2 and swapped the motor leads -- still chattered on rear motion only. Other info, this TX has been successfully used more than 6 months. Probably out of warranty by now. Other components are a MambaMax and the RTR Axial 55T motor. Anyone had any experience with the FlySky generating a chatter, or studdering in one direction only? Any thoughts of what to check? Thanx for any suggestions. |
06-06-2012, 07:23 PM | #2 |
| Re: FlySky troubleshooting
Plug a servo into the throttle channel to see what kind of signal is getting through the channel. That should help verify that it is indeed the radio. If it is, start with a fresh model and see if that helps at all. You guys didnt turn ABS on did you? |
06-06-2012, 07:30 PM | #3 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
Make sure ABS is set to OFF.
06-06-2012, 07:51 PM | #4 |
x2, make sure ABS is OFF.
06-07-2012, 10:14 AM | #5 |
ABS was on. Turning it off fixed the problem. He doesn't know how it got turned on, but was not on purpose. Says to pass on "Thanks, you guys are great." |
06-07-2012, 04:24 PM | #6 |
You can send payment to my paypal, $100! Glad you guys got it sorted out. |
06-09-2012, 03:02 AM | #7 |
Newbie Join Date: Sep 2011 Location: Fort Smith
I'm having the same problem with my gt3b (not hacked). ABS is off. I have an AX10 with AE-2 esc, rc4wd 35t motor, TowerPro MG995. When I calibrate the tx to the rx, it always takes a second to find neutral throttle. Also when I turn the esc on, it takes longer to sync. When it's sitting still, it all the sudden will take off in reverse about 1/2 throttle and I have to use forward throttle to make it stop. Any suggestions? |
06-09-2012, 08:40 AM | #8 | |
| Re: FlySky troubleshooting Quote:
not the same problem at all... did you calibrate the ESC to the Tx? sounds like the ESC thinks Tx neutral is half power reverse.... | |
06-09-2012, 09:00 AM | #9 |
| Re: FlySky troubleshooting yes the esc is calibrated to the tx. It worked fine before, it just started this a few weeks ago. I'm thinking there might be a problem with the trigger
06-09-2012, 01:19 PM | #10 | |
If that doesnt work then hook a servo up to the throttle channel and use the trigger, see what the servo does and figure out if there is a problem. | |
06-11-2012, 07:33 AM | #11 |
I figured it out last night. Ch 2 expo setting was at 0 so I changed it to -24. Recalibrated - Problem solved. Thanks for the help fellas. |
FlySky troubleshooting - Similar Threads | ||||
servo troubleshooting | hibbs | Electronics | 2 | 08-14-2011 08:01 AM |
Need help troubleshooting | cavecrawler | Electronics | 6 | 02-22-2011 10:03 AM |
troubleshooting help with the dx3r please? | m-boromotorhead | Electronics | 3 | 02-26-2009 09:37 PM |
Noob needs some troubleshooting help | GOBIG | Electronics | 2 | 10-10-2006 05:19 PM |
