06-10-2012, 07:35 PM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
| Axial AE-2 Esc Troubleshooting Help
Hello there, My names Nathan and I'm having a problem with my stock Axial ESC, I turn the truck on, it runs fine, for about 10 minutes, then the ESC gets hot, and all 3 lights begin to flash, now I'v read about thermal shutdown on these things, but it has stock gearing, and the gear mesh is spot on, I'v taken the motor off and tried a different one " Thinking the motor had demagnetized and was pulling to much current" had that happened to me before, so here in lies my problem, I have no idea why this is happening, I'v searched here, scale4x4rc, URC, RcSparks, all the normal forums, but absolutely no info on what it means when ALL the lights flash, any help would be much appreciated, thanks guy! |
06-10-2012, 07:43 PM | #2 |
| Re: Axial AE-2 Esc Troubleshooting Help
Since it's close to a CC ESC..... read this (near the bottom)..... Castle Creations | FAQ: 1/10th Scale Products |
06-10-2012, 07:52 PM | #3 |
okay, i understand that, i guess i need to rephrase my question what does it mean when the esc heats up and then all 3 lights flash, the heating up part of this is whats stumping me, Charlie-III thank you for the help on that faq, im just stumped as to what the heat issue may be? any thoughts?
06-11-2012, 08:45 AM | #4 |
Are you running a 3S pack....... with a digital servo........ and no external BEC?
06-11-2012, 10:11 AM | #5 |
You may have 2 different issues. The LED's sounds like a RX issue. The heating sounds like an overgeared motor that is drawing too much. I would remove/reseat all the RX connections to make sure they're clean and solid. I would also check the drivetrain for binding, overtight pinion/spur gear mesh, lube motor bearings/bushings and go from there. You state you've used different motors & the mesh is "spot on", but check the driveline anyway. What kind of rig? Scaler, worm drive, etc.? |
06-11-2012, 05:43 PM | #6 |
stock wraith rtr untouched as far as upgrades
Axial AE-2 Esc Troubleshooting Help - Similar Threads | ||||
FlySky troubleshooting | WAM | Electronics | 10 | 06-11-2012 07:33 AM |
servo troubleshooting | hibbs | Electronics | 2 | 08-14-2011 08:01 AM |
Need help troubleshooting | cavecrawler | Electronics | 6 | 02-22-2011 10:03 AM |
2 days after it's new, I need troubleshooting tips...esc maybe? | TrailerCraweler | Axial SCX-10 | 6 | 11-15-2010 05:44 AM |
Noob needs some troubleshooting help | GOBIG | Electronics | 2 | 10-10-2006 05:19 PM |
