06-10-2012, 10:08 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Rocky Hill
| Castle sv2 melted
I got a never used castle sv2 with 5700 kv motor combo for my son's slash. I 've been running it on a 5000 mah 3s lipo which it is supposedly rated for. I put about 2 packs through it but it was WAAAy too fast. So I bought an inexpensive 3900 kv motor off of ebay that was supposed to handle 3s as well. . I ran 2 packs through it but it got CRAZY HOT. I said screw it let's run it till it fries, which was by the end of the second pack. Tried to run it a third time but it barely moved. So I went back to the 5700 combo motor. Used the truck for 2 or 3 minutes just to check it. Everything was fine. The next day all my step son did was plug it in and POOF up in smoke. It melted the battery wires off the esc and the case is visibly deformed. I know he plugged the battery in correctly because I use deans plugs. So my question is this, was it something I did to cause this to happen or are the sv2's prone to spontaneous combustion. Thanks all! |
06-10-2012, 10:40 PM | #2 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: Castle sv2 melted
The axial scx10 esc with drag brake is acualy the sv2 without the 3rd wire, and its rated for 2s lipos, and 6 cell nimh. And if u were running contimuously through the packs, with out a break, that could have done it. Also, and I'm just makin sure, u absolutly HAVE to let the battery cool before u charge it then let it cool after charging to run. And its problably a good idea to let the esc cool after runs, just so u don't let it get too hot. |
06-10-2012, 11:54 PM | #3 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
sounds like your pinion was way too high in the slash with the motor/esc you were running, that would be my guess as it is rated for 3s not 2s max like fordrox97 said. or you had the gear mesh way too tight or there may have been a diff problem |
06-10-2012, 11:57 PM | #4 |
or its just castle smoldering like they are known for doing, lol.
06-11-2012, 01:43 AM | #5 | ||
| Re: Castle sv2 melted Quote:
The brushless sv2 and brushed Ae3 are not remotely the same internally. They share the same case that is all. Additionally if you read my post you'll see that my set-up IS rated to handle 3s. As far as running the batteries continuously, no I did not. I only have one battery for it. Quote:
Didn't know this ... | ||
06-11-2012, 07:38 AM | #6 | |
dude, i just took my truck apart, and looked at the circut board. i already knew the esc is castle, and i had yet to find out. but when I looked at the circut board, there was a hole in it for the third wire. so i looked up the ae-2 esc, and there poped up the Sv2 | |
06-11-2012, 10:24 AM | #7 |
| Re: Castle sv2 melted The OP is using lipo.. The cells don't care if they are hot or not when you charge, and charging actually COOLS them down. Just a FYI.
06-11-2012, 10:32 AM | #8 | |
As to the issue with the sv2, the issue was likely either the cheap motor u bought wasn't up to the task of 3s even if rated to it and may have caused some internal damage to the sv2 and then it gave up with the 5700 motor, or it just gave up as I have heard a fair number of issues with the sv2 that's why I always search for used original sidewinders. Sent from my iPad using Tapatalk | |
06-11-2012, 03:11 PM | #9 |
I have to admit that this is my first go at the brushless stuff. What I don't understand is, how a motor can cause an internal failure of the esc?
06-11-2012, 03:24 PM | #10 | |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
Brushed or brushless... a motor that has shorted windings or is stalled can take out an ESC faster than you can say "magic smoke" | |
06-11-2012, 03:54 PM | #11 |
I know it's odd but can happen. I bought a cheap 4000kv motor and rant on 3s on one of my sidewinder (v1) and it made the esc quit working for brushless. Whenever it had a all 3 wires hooked up and just turned on it would heat up. Funny thing is I set it to brushed mode and it worked fine and is still in use on my xr10 a year later, just the brushless part of the circuitry fried (lucked out there). So for all my 3s brushless use I will only use a castle mamba max pro and even it gets almost to the borderline of hot Sent from my iPad using Tapatalk |
06-11-2012, 04:20 PM | #12 | |
Hard to say if it was a result of use/abuse, or just something that happened. I gave a buddy a brand spanking new Tekin FXR and as soon as he plugged in a battery, poof. Holmes recently posted somewhere that he triple checks his ESCs before he ships them to the customer, but as soon as the customer hooks it up, poof. | |
06-11-2012, 05:40 PM | #13 |
So it's probably my fault because I decided to "kill" the cheap motor. Stupid mistake I won't make again. But yeah the thing was a "rocket". You couldn't reach top speed because too much air would get underneath and just cause it to flip over. It really was uncontrollable though... impressive but uncontrollable. Thanks all for the info! |
06-11-2012, 05:48 PM | #14 |
| Re: Castle sv2 melted |
Castle sv2 melted - Similar Threads | ||||
Castle Sv2 | shwng1973 | Newbie General | 1 | 09-19-2011 09:40 PM |
Castle - SV2 issue | hung0417 | Electronics | 21 | 08-07-2011 12:09 PM |
Siderwinder SV2 Castle link help. | headhunter555 | Electronics | 1 | 05-06-2011 10:30 PM |
Castle Creations Sidewinder SV2 | KC_JoNeS | Electronics | 20 | 03-05-2011 06:20 AM |
