07-06-2012, 07:54 PM | #101 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
| Re: Anyone Use Brushless Hobbies 120A ESC?
i ordered mine yesterday! i am excited to get it. stan is a great guy to deal with. he helped me out with my website issues with the shipping for my address, and shipped it the same day! it should be here on tuesday! OK to SWPA in 3 days, not too shabby!! also, where do you get the programming software for this speedo? does stan email it to you, or is it a general program out on the web? and.... even though this is only a 120A esc, could this handle running an 1/8th scale buggy? the specs only list it as being able to only take 3s, but could it take 4s and not cook? |
07-06-2012, 08:50 PM | #102 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
He should email you. So mine seems to have lost some settings since the last run on wensday. Not sure what the deal with that is. going to take my laptop tomorrow just in case. |
07-07-2012, 08:59 AM | #103 |
holy crap is stan fast! i just ordered my unit thursday afternoon at almost 3PM eastern time, and it is down at my local post office this morning!!! it just sucks that my brother in law is using our truck to go to work at the moment, and i won't be able to get down there until monday... |
07-07-2012, 10:03 AM | #104 | |
| Re: Anyone Use Brushless Hobbies 120A ESC? Quote:
07-07-2012, 11:35 AM | #105 |
Okay, i see what is going on. I crawl up on a obstacle and stall. then i go to pin the throttle, if the motor is right at the turbo kick in RPM, the ESC reads the motor as stalled out and stops pushing power, so not forward and no drag, the truck then free wheels back. I could fix this by cranking the boost start RPM way up, but i need the wheel speed, i think the best fix would be to allow for boost start RPMs lower then 3000 RPMs, say 500 to 1000 or even instant. other then that, i love this thing.
07-09-2012, 10:06 AM | #106 |
I dropped Stan an e-mail inquiring about a new firmware with the turbo setting either instant or even with some settings below 500 RPMs.
07-09-2012, 12:58 PM | #107 |
So, does the turbo setting just increase timing at a certain RPM? If so, could you just turn it off and set the timing to whatever you need? I'll be doing RC stuff this weekend so maybe I'll get around to swapping that ESC into my Wraith with the brushless motor I have for it. It's only 1000kv so with my 2s battery that's maxing out at 8,400rpm seems pretty slow but should be able to gear up.
07-09-2012, 01:28 PM | #108 |
I never could get the turbo shut off completely, I made things better, but never resolved. maybe it is just kicking up the timing, that explains a lot, I assumed it was controlling voltage output. Maybe I need to set my base timing to the same as the turbo??? or something like that.....
07-09-2012, 01:40 PM | #109 |
Which firmware are you using? I remember seeing that there were a few that didn't include the turbo boost setting. I think those were for sanctioned racing. It might be worth checking those to see if one allows you to disable the boost setting yet add timing. I'm at work now so can't check the settings.
07-09-2012, 02:13 PM | #110 |
good idea, i would still like the function of delay, but worth a shot i guess. I'm at work too, will check it out tonight.
07-10-2012, 05:32 PM | #111 |
i finally got mine yesterday! damn is this thing small!! it looked much bigger on the screen!!! i like that stan throws in an extra sensor cable! so far in my motor shopping, it seems that a lot of the motors come with a sensor cable. now i just need to wait for my lipo and "deans" connectors to get here from hobby king, and get to the LHS for some bullet plugs! another question i am wondering, is since this is a sensored/sensorless ESC, would a sensorless motor be adaquate for just bashing around in a 2wd stampede? i also think i am going to order a my new charger from stan, too! i am in need of an upgrade from my .8amp/hr charger i have been using for my 1000-1300mah crawler lipos, now that i am running a 5000mah lipo!! |
07-10-2012, 05:36 PM | #112 |
A sensorless motor is just fine in a basher or racer. Have fun! |
07-10-2012, 07:42 PM | #113 |
okay, talking to Stan about this, but now i think the 528 mod is fine. here are my settings. I tried all the other programs tonight, before i started i tested the truck. it was still doing the boost delay. so I went through all of the programs and came back to 528 mod as it had the options i was after. i flashed it, set it and tested. it did exactly what i wanted for about 4 minutes, then started delaying again. I flashed to a different program, flashed back to 528 mod and set it again, ran it around the floor and it was fine. didn't revert this time. so I pulled the power, discharged the the system, let ti sit, powered back up and tested. it was fine. i am going to let ti sit till tomorrow night and try it again. it's like it is not holding it's programming, but when i would look at it after it started acting up, all the settings where fine. no idea. |
07-14-2012, 10:05 AM | #114 |
Rock Stacker Join Date: Aug 2011 Location: UT
Make sure your flashing it twice, HW stuff needs the firmware to be loaded twice also..
07-14-2012, 02:36 PM | #115 |
| Re: Anyone Use Brushless Hobbies 120A ESC? |
07-14-2012, 04:46 PM | #116 |
07-16-2012, 05:16 PM | #117 |
07-16-2012, 05:59 PM | #118 |
Stan and I are discussing this. Saturday it started miss behaving. I shut it down for most of the day then ran it that night and it was fine with no reflash between. No idea what is going on, but it seems to get better each run.
07-30-2012, 07:12 AM | #119 |
Quick note, for those testing sensored brushless with the motor on the bench, you'll need a load on the motor for it to perform properly. I stuck an old stripped pinion on the motor and held the pinion with a rag and you can see night and day that the sensored stuff is working very nice. The motor even has a totally different sound when sensored and when unsensored.
07-30-2012, 08:09 AM | #120 |
okay, so last time i ran my truck, it was performing fine. and when this rig preforms fine, it is a magical thing LOL. I think all the issues i have reported are limited to my rig. next time i need a brushless ESC, it will be a brushlesshobbies.
Anyone Use Brushless Hobbies 120A ESC? - Similar Threads | ||||
Venom PRO Brusshles ESC 120A | BL-4x4 | Electronics | 1 | 01-04-2012 11:10 AM |
