06-14-2012, 07:57 AM | #1 |
RCC Addict Join Date: Jun 2010 Location: Australia NSW
| please help me with my setup.
Hi guys, im trying to set up switching for my lights on my scaler. i found a few examples of using a cheap esc to power lights via the motor output and by tweaking the endpoints to control voltage. i have a turnigy 9x with its matching rx (hobbyking) and my HSP ESCs work fine on it, no problem there. the problem becomes when i try and use my MiniQLO ESC on the switched channel, like making the gear go up or down. it works fine on the regular channels, like say, throttle. turn on the rx, turn on the TX and it loads up and sings its song. and if once its connected i swap channels it still works and does what i want it to. but, its when i plug it into (ch6 allocated to the gear) and fresh start: TX on, ESC on, MiniQLO ESC on, it wont load up, like its looking for a signal. i even tried leaving it for a moment thinking it might take slightly longer. but still not until i change which channel its on, that it connects to the TX. is there a better way for running lights? or is this going to be an issue ill have to work around? i thought about using the circuit board out of a servo, but not sure if it will give me 6v?? any ideas? second half of my inquiry, based on the same topic. my head/hibeam/spotlight circuit is 14.4v, i had planned to run it via a 6v relay that was also switched via the RX, but since actually researching it, seems im going to need to do it a different way as the output is PWM?? not an variable voltage like i thought. please help! this is the first time ive even played with my 9x and the learning curve is quite steep! |
06-14-2012, 02:19 PM | #2 | |
| Re: please help me with my setup. Quote:
I'm not familiar with your radio, but I have lights on a switch on my 4pks. I use a servo board. It will pass 6v to the lights. It took a little playing around to find the 'sweet spot' on the pot. Once I found that I CAed the pot in place, set a switch on the tx to 2 position and have on\off from the radio. Here is a little vid of when I first got it working. | |
06-14-2012, 07:24 PM | #3 |
does anyone know if a micro servo servo will have the same voltage going to the motor as a 1/10 size servo?
06-14-2012, 10:14 PM | #4 |
| Re: please help me with my setup. Last edited by losikid; 06-14-2012 at 10:16 PM. |
06-14-2012, 10:35 PM | #5 |
i saw those, and altho yes, theyre very nice, i was trying to get out of it using parts i already have. if it comes to the crunch and i cant work it with either a servo board, or an esc, then ill get myself one of his switches.
06-15-2012, 09:14 AM | #6 | ||
4 Position Dual Powered Dual RC Switch Quote: | ||
06-15-2012, 04:15 PM | #7 |
thanks heyok. they were the ones i was looking at. Yesterday i pulled an old micro servo to bits and was successful with it so just gotta do the same to a second one and im set. Thanks for your input. |
06-16-2012, 07:22 AM | #8 |
so can anyone tell me why the ESC wouldnt find the signal when on the switched channel? but would on the other channels?
06-16-2012, 07:27 AM | #9 | |
My Castle stuff will just sit there waiting for a calibration if it feels that the servo signal is too far from the center position when it powers up. Maybe you could get this to work if you adjust the end point of this two position channel so that the ESC sees the servo signal in the middle of its range when you power it up. | |
06-16-2012, 07:34 AM | #10 |
hmmmm thats a really good point actually. perhaps ill have a look into that one. ill let you know what i come up with, if it works.
please help me with my setup. - Similar Threads | ||||
Is my setup right? CKRC Stage 2 setup - front axle castor | Miller Time | Axial AX-10 Scorpion | 14 | 03-01-2008 12:54 PM |
Clod axle setup VS Shaft setup | jrscycle | Newbie General | 6 | 12-21-2005 09:21 AM |
