06-19-2012, 07:22 PM | #1 |
Rock Crawler Join Date: Apr 2011 Location: SD
| Integy 35T -what pinion gear?
All i've ever ran on my scx10 (7 lbs roughly) is 35t's by Integy with a 17 tooth pinion gear. Lately it's been running hot, so hot I cant touch it without getting burned and it feels like the rig looses power gradually (running a 2s) and there is a slight burning smell at the end of my crawl (is that normal ? ) Here come the questions: What pinion size can I change to on my 35t gain torque and still run cool? ( I don't mind loosing wheel speed ) If I run a 45t or 55t what pinion size is recommended? This might be my avenue so that I can gain some torque, but would like some advice based on experience. Is there a thread with turns to pinion gear match and what are the results? Thanks for the feedback fellas Happy crawl'n |
06-19-2012, 07:31 PM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Integy 35T -what pinion gear?
Your best bet is start with a smaller pinion and see how it does. Try a 14-15 tooth and it should run cooler without a huge loss of wheel speed. The 35t motor should be fine in the truck but the smell and heat sounds like it's geared a little high.
06-19-2012, 07:31 PM | #3 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
I don't see anything wrong with your pinion for that setup, surmising you're running a 87T spur. I'd say the motor needs a replacement. 87/17 gives you a 5.11 ratio. I'm running a higher ratio (56/13 32P) with the stock 27T Axial motor and it runs fine. I can run it solid for two hours and it never gets hot. I might be a tad lighter than 7 lbs. Stick with a 35T motor, but a better brand. |
06-19-2012, 08:13 PM | #4 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
I use the same motor and I run a 14 t pinion and 87 t spur! I had heat issues with mine as well and found my gear mesh was too tight. I adjusted that and it gets warm but not hot! So would start there!
06-19-2012, 08:38 PM | #5 | ||
Thanks fellas. Looks like the 35t is the way to go with a lower pinion gear. Spur gear is stock so I won't even mess with that. Quote:
06-20-2012, 01:29 AM | #6 |
I am running that set up in my shafty. Integy 35t, with a 14/87 and it barely gets warm. I run mine on 3s and it's got lots of torque for a cheap motor.
06-20-2012, 01:46 AM | #7 |
Newbie Join Date: Jun 2012 Location: Italy
| Re: Integy 35T -what pinion gear? |
06-20-2012, 08:54 AM | #8 |
I agree that the gearing sounds right. You probably overheated the motor once and degaussed the magnets. Now you need a magnet zap to bring back the torque and keep it from overheating.
06-20-2012, 08:26 PM | #9 | |
thank you gentlemen, I just picked up a 45T and a 15 pinion on my stock 87 spur. Should I go a few teeth down on the pinion? btw, very imformative site Mr. Holmes Brushed Motor Selection and Gearing Guide by Vehicle | The Search for Power Quote:
06-20-2012, 09:52 PM | #10 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I run a HH 35t handwound on 2s with 24/87 gearing currently. A good handwound will last you a long time with a little care and maint. In my experience the Integy motors need work right out of the box. The comm is lumpy among other things.
06-21-2012, 01:21 AM | #11 |
[QUOTE=z71baja;3787569]thank you gentlemen, I just picked up a 45T and a 15 pinion on my stock 87 spur. Should I go a few teeth down on the pinion? I'd stick with a 14t pinion. The 24/87 is high geared for a crawler and can only be handled by a quality motor. Until you get a good motor I'd say run the 14/87. I have a HH 27T Torque Master Pro in another one of my shafty's and I run it the same 14/87 and it provides more than enough wheel speed. |
06-21-2012, 06:59 AM | #12 |
Thanks! I have a pretty big list of things that still need to be added to the site, its just a matter of having 25 hours per day to get things done Your pinion sounds fine, 15t is a great start. |
01-18-2013, 08:01 PM | #13 |
Newbie Join Date: Oct 2012 Location: Kilmarnock
| Re: Integy 35T -what pinion gear? I have a hh torque master 35t on my scx10, great motor. was alright on my 2.2s but trying to head in a more scale direction so I bought some 1.9s but it's just a little too slow. gearing is stock. what pinion do I need to up my speed?
01-18-2013, 08:09 PM | #14 |
16-18 would be a good start.
01-18-2013, 08:11 PM | #15 |
so what's the stock pinion?
01-18-2013, 08:12 PM | #16 |
Don't have a clue. The owners manual should tell you.
01-18-2013, 08:40 PM | #17 |
ok so I have the rtr honcho and it comes with 20t pinion. so I'll need to go bigger to get more wheel speed right?
01-18-2013, 08:44 PM | #18 |
Yes, as long as the motor doesn't get hot. If speed is what you are after, either run more voltage or a lower turn motor. |
01-18-2013, 09:09 PM | #19 |
can the AE-2 handle 11volts?
01-18-2013, 09:16 PM | #20 |
Yep, but you'll need to pick up a bec to keep your servo voltage up, otherwise you will more than likely brown out and shut down.
Integy 35T -what pinion gear? - Similar Threads | ||||
rc4wd 35t vs. integy 35t | ninetwofiveRC | Electronics | 22 | 01-02-2012 09:59 AM |
Which pinion on 35t Integy Pro Lathe for the LNC? | Voteban | Electronics | 0 | 02-25-2010 09:05 PM |
Tekin 35t vs Integy 35t | Hoppa | Electronics | 10 | 10-10-2009 06:47 PM |
holmes 35t vs. integy 35t | 2500hdon37s | Electronics | 14 | 04-25-2009 09:28 PM |
