06-21-2012, 05:38 PM | #1 |
Rock Stacker Join Date: Nov 2004 Location: Sherwood Forest - UK
| Front Dig - Old Skool switch questions
I need a little help please. I have a spare 2 way channel on my transmitter. I'm thinking about using it for a front dig to my clod based crawler. I don't want to splash out on a RC Punk unit (plus I don't have a 3 way channel spare) so thought I'd go back in time & use a basic switch, especially since I have one kicking about. I have a few questions I'm sure the more experienced of you will be able to answer with ease. 1 - I'm using an old Traxxas EVX, powered by a single 2S LiPo, driving a pair of lathe motors. Should I start using a switch to disconnect the motor & short it out, will I damage the motor or ESC in any way? 2 - I understand that the switch will burn out eventually, how quickly will it die & can it cause damage to anything else when it does? 3 - Finally, do I have the wiring correct? Sorry for the bad diagram, I'm lacking in MS Paint skills. Thanks in advance for all your help Newth |
06-23-2012, 02:08 PM | #2 |
| Re: Front Dig - Old Skool switch questions
Come on guys, any thoughts please?
06-23-2012, 02:10 PM | #3 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
you can disengage the motor by removing the ground side using a 24v switch. Last edited by SwampDawg; 06-23-2012 at 02:17 PM. |
06-23-2012, 06:03 PM | #4 | |
| Re: Front Dig - Old Skool switch questions Quote:
06-23-2012, 06:20 PM | #5 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
Yep, as HeyOK said, thats perfect. I'd just like to add though, because your driving a pair of motors from a single ESC, just be careful that you have each motor wired separately from the EVX, and not paralleled otherwise you'll be disconnecting both motors. |
06-24-2012, 11:36 AM | #6 |
Thanks for the replies guys. That's great. Will the EVX be damaged using the dig? I presume it won't, but thought I'd ask those with more experience than me. Here's a link to the switch I have kicking about. Will it be good for the job? I think it would certainly be a neat & tidy answer. BattleSwitch Radio Controlled 10A Relay Switch If no good, would I be better with a micro switch & a servo to make/break it? Thanks for your help Newth |
Front Dig - Old Skool switch questions - Similar Threads | ||||
Can you use a punk dig to switch between front and rear winches? | scarstens | General Scale Talk | 13 | 02-28-2012 08:17 PM |
front dig switch | jgb7038 | Electronics | 3 | 02-19-2008 07:01 PM |
Front Hi/Lo switch removal | JasonInAugusta | General Crawlers | 11 | 01-26-2007 03:20 PM |
