06-23-2012, 06:40 AM | #1 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
| Charging issues
Since I got into lipos i have been using a CORE-rc udc-20 charger... I get it, its not hyperion... its a huge peice of shit but it gets the job done. This charger is probably the most anal thing ive ever used... For some reason, when trying to charge a nimh battery is just says "Battery voltage error Cell connect" what the hell does this mean? My connections are perfect... the batteries are brand new... I cant even charge the damn thing on 0.1 amps.. |
06-23-2012, 07:55 AM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Charging issues
I had another version of this charger. Same charger different label and paint scheme. It worked well for a long time but started giving various errors when trying to charge. When I replaced it the same batts charged fine. I looked at the manual for the one you have and that error isn't listed. http://www.racing-cars.com/images/pd...structions.pdf |
06-23-2012, 08:10 AM | #3 |
| Re: Charging issues
I don't have the charger, but a few questions for you. 1-What are you setting the charger to? 2-Did it work before on the same/similar packs? PS, read the manual, pretty straight forward. Last edited by Charlie-III; 06-23-2012 at 08:13 AM. Reason: Added "PS" |
06-23-2012, 08:29 AM | #4 |
| Re: Charging issues
Thanks guys. 1- I am setting the charger to NIMH to charge a 2000mah 6 cell NIMH pack at 0.5 amps 2- Yes, ive used this charger for 3 years charging stick packs of various sizes, and up to a month ago charging smaller nimh packs in my 8th scale buggy. I am reading the manual that SINister, and as he said the error isnt listed. I dont understand this issue one bit and its quite annoying |
06-23-2012, 08:37 AM | #5 |
| Re: Charging issues
Maybe something got into the balance port? It could be causing an issue that the charger does not like. The error sounds like a "balance charge" issue, but it's not needed with NiCD/NiMH. |
Charging issues - Similar Threads | ||||
LIpo charging issues | tzque | Electronics | 20 | 06-19-2012 03:45 PM |
Charging issues need help! | yel98vwgti | Electronics | 0 | 05-20-2008 03:34 AM |
1:6 Nylint Battery charging issues | Boonie Buster | General Crawlers | 4 | 02-29-2008 04:16 PM |
Charging Issues/////Help | hlpressley | Electronics | 7 | 12-10-2007 10:30 PM |
Battery Charging Issues | Nylintjunkie | Electronics | 0 | 08-02-2006 11:21 PM |
