06-24-2012, 10:49 PM | #1 |
Rock Crawler Join Date: Feb 2012 Location: Wisconsin
| Front motor & esc
I'm having trouble with my MOA crawler's front motor. When I am in 4 wheel drive and I go into 4 wd reverse it's fine but when I stop then try to go 4wd forward only the rear motor will drive forward. I can then select front motor dig only and it works fine then I go back to 4wd drive and all is good again. The problem only arises when I go into 4wd reverse then try to go 4wd forward. Anyone have an idea what's wrong ??? It has new Holmes motors, new Micro Mambo's, new castle bec. |
06-24-2012, 11:21 PM | #2 |
| Re: Front motor & esc
Plug both sec's in to castle link, make sure they have identical settings, look at the forward\reverse settings. Make sure they are on the same firmware version to.
06-24-2012, 11:27 PM | #3 |
| Re: Front motor & esc |
06-25-2012, 05:20 AM | #4 |
Sounds like one has a double pump forward/reverse setting. Part of what I like about CC ESC's (or ESC's based of the CC programming) is that you can make a profile for one ESC (brake type, motor type, throttle curves, etc.) save it and then load it into another ESC. Start with the same firmware though. |
06-26-2012, 10:11 PM | #5 |
Turns out it was a programming issue. One of the settings was put on a 2 second delay to go forward after reversing. Problem fixed !
Front motor & esc - Similar Threads | ||||
dual esc front motor before rear | losiredcatcrawler | Redcat Crawlers | 0 | 03-14-2010 09:34 PM |
Esc & Motor ?? | SD333 | Electronics | 5 | 12-29-2007 04:31 PM |
