06-26-2012, 03:47 AM | #1 |
Newbie Join Date: Aug 2011 Location: ireland
| No power to motor
Can anyone please help. Just wiring up my first ever crawler and Ive run into 2 problems. 1: Ive no power to the motor...These are 2 pictures of how Ive soldered the wires to the motor (positive and negative) Battery 1 Battery 2 And this is an image of the motor attached to my ESC (Castle Sidewinder V2) Battery connected to ESC I seem to be getting power to the servo to turn the wheels so I know its not my ESC or battery that is at fault. Can anyone spot whats wrong or suggest a fix? The only thing that I might add is that the gauge of wire that is attached to the motor is bigger than the gauge that is coming from the ESC (ive soldered them together in the middle). Might this be the problem, although I wouldnt have thought so...? 2: My servo arm's connecting screw keeps on loosening when the wheels are turned making the servo spin but not the arm. Again, below is a picture of what I mean. The screw that hold the arm in place goes here. Where the screw attaches the arm to the servo This is the screw that I am using (came with the crawlers kit), and the small washer type thing came with the servo (however, no instructions came with it) The connecting screw and the washer type thing that came with the servo Does anyone have any suggestions re. either of my issues as I am so close to completing this thing after having it sit on the shelf for the last year (had no time to build due to college work). I am itching to get out onto the rocks.... |
06-26-2012, 04:41 AM | #2 |
| Re: No power to motor
1-I believe that ESC comes set for brushless, needs to be set to brushed. 2-Did you calibrate the ESC to the radio? If not, the servo will have power but the motor won't run. Castle Creations | FAQ: 1/10th Scale Products http://www.castlecreations.com/suppo...s_ed_guide.pdf |
06-26-2012, 05:23 AM | #3 |
Sounds like Charlie's got the motor issue, you need a metal horn to fix the servo, sounds like the plastic one stripped.
06-26-2012, 05:36 AM | #4 | |
Rock Stacker Join Date: Mar 2012 Location: U.K.
| Re: No power to motor Quote:
+1 on the stripped servo horn my wraith eats them for breakfast | |
06-26-2012, 07:17 AM | #5 |
| Re: No power to motor Sorry should have mentioned but no, the horn is metal and the screw holding it onto the servo literally loosened after turning the wheels 2 or 3 times only. The problem is that the screw gets loosened. I might try some thread lock and see if this helps. Thanks for the comment though.
06-26-2012, 07:19 AM | #6 | |
Ill try it as soon as I get home tonight thanks. | |
06-26-2012, 08:37 AM | #7 | |
Robitronics & Imex (?) are even better, but I use the GHracing with good results. Let us know what happens. | |
06-26-2012, 09:58 AM | #8 |
The thread on that screw might not be correct. I've had some servos need coarse thread while others used fine. I use a dab of blue loctite to keep it in.
06-26-2012, 10:01 AM | #9 |
Before you goob a bunch of glue or threadlock on that servo screw, post up a pic of the BACK of your servo arm. Either the splines on the inside of it are stripped, or it's one of those "fits all" arms that uses inserts and you're using the wrong one, or not using one at all. The ONLY function that screw should serve is to stop the arm from falling off, it should never be expected to 'hold' the arm from spinning, that's why there's splines in there.
06-26-2012, 10:04 AM | #10 |
That's true. All of the good servo horns I have had required you to press them on to the splined shaft and use a screwdriver to wedge in and get enough leverage to pull them off. I just use the loctite to keep the screw from coming out and letting the servo arm back off. Trubble is right, the horn will say the number of splines usually and that needs to match the servo. |
06-26-2012, 04:00 PM | #11 |
| Re: No power to motor So the update is as follows, tried the calibration of the ESC to the transmitter and got power to motor. But when I say power, I mean not constant power. Its like the power cuts in and out all the time, making the motor run in a jerking fashion. I tried the battery directly to the motor and that seems to be running smooth. But the second I hook it up to the ESC the motor start jerking. Could this be a problem with the ESC (although like I said the steering is working silky smooth - when the screw doesnt come unstuck), or is it a problem with the calibration of the ESC to the transmitter? I've also cut the wires from the ESC to the motor and re-soldered them thinking that the soldering joints could be the problem but still I'm having the same issues. Its really staring to frustrate me. Does anyone have any ideas why this could be happening? |
06-26-2012, 04:12 PM | #12 |
As said, it comes programmed for brushless. You need to set it for brushed as well as set up the correct foward/dragbrake/reverse mode and set the drag strength.
06-26-2012, 04:18 PM | #13 |
| Re: No power to motor |
06-26-2012, 04:24 PM | #14 | |
Next time maybe I do my homework a bit more and see which horns will fit the servo. Thought all servo fittings were the same.... | |
06-26-2012, 04:30 PM | #15 | |
06-26-2012, 04:51 PM | #16 |
| Re: No power to motor Yeah just revisited the manual as I could remember how I had it set-up, but i definitely have it set up to brushed. But still no luck, the motor keeps cutting in and out, like its only receiving power in bursts/intervals
06-26-2012, 04:59 PM | #17 |
Page 20 of the link to the manual Charlie posted, it'll be difficult as you probably won't hear the beeps until its set to brushed. Castlelink is the fastest, easiest way.
06-26-2012, 05:18 PM | #18 |
| Re: No power to motor Thanks Indiana Mudcat, I will try this tomorrow evening and let you know how I got on. Turns out I was following the wrong instructions all along. Was following the instructions that came with the transmitter when I should have been following the ones that came with the ESC. Why oh why do they make it so complicated.... |
06-26-2012, 05:20 PM | #19 |
Does someone near you have a castle link or field card? You can always run to the hobby shop and ask them to put it into brushed mode for you. That way you can be sure it's correct.
06-26-2012, 06:18 PM | #20 | |||
If you're working on the radio, use the radio instructions. If you're not sure, ask here. | |||
No power to motor - Similar Threads | ||||
No power to motor? | diggindeep | Electronics | 4 | 10-21-2011 02:17 PM |
FX-R PRO no motor power | j22 | Electronics | 1 | 10-05-2011 02:18 PM |
Power wheels motor? | airdreams1 | Electronics | 1 | 09-21-2011 11:04 PM |
Power Wheels motor??? | Heavy | Electronics | 11 | 09-17-2005 11:08 PM |
