07-24-2006, 05:45 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
| moped v16r esc's
is anyone running them and if so how in the h e l l are you programming these things ?
07-24-2006, 05:47 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
you push and hold the button till the light comes on, go to full throttle and hold it there while you push the button, then go to full reverse and hold it there while you push the button. Don't feel bad I had to program 2 for one rig
07-24-2006, 06:05 PM | #3 |
thats what im doin programming two
07-24-2006, 06:31 PM | #4 |
Moved this to electronics. |
07-24-2006, 08:13 PM | #5 |
Rock Crawler Join Date: Jun 2005 Location: Safety Harbor
I HAD one but it wat defective out of the box.Sent it back,now its been the BIGGEST headache trying to get it replaced.Hope you can get it programmed some how.
07-25-2006, 07:02 AM | #6 |
Kamikaze, how did you wire the 2 mopeds? 12flex are you sure you hooked up the moped to ch1 or 2 on your receiver not on the batt slot? i did that on mine it move the sterring servo but nothing else, until i realized it was on the batt slot instead of the ch 1 slot on the receiver , it happens .
07-25-2006, 08:05 AM | #7 |
| 2
im trying to run 2 moped v16r's 1 plugged into slot 1 and the other on slot 3 steering is 2 and 4 this way i move my sticks forward my truck goes forward and the steering for the the frnt is the left stick and the rear is the right stick. i have full control i will be able to do front or rear digs. BUT I CAN GET THEM PROGRAMMED RIGHT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!:-( |
07-25-2006, 08:14 AM | #8 |
RCC Addict Join Date: May 2006 Location: USA
i love my moped, it works great, i run it on my gecko2 pro clod with (2) 645mg servos and i dont need a receiver pack. there is a slight reverse delay but nothing major, run the truck a couple times and you dont notice it anymore.
07-25-2006, 08:18 AM | #9 |
great glad your happy with your one your post doesnt help me out much like i said im trying to run two and im having problems with the programming i got a stick with moab xls 2 batterys 2 motors 2 servos 2 escs 1 receiver |
07-25-2006, 08:59 AM | #10 |
did you try one moped at a time? did they work properly one at a time?
07-25-2006, 09:00 AM | #11 |
yeah they do
07-25-2006, 09:18 AM | #12 |
then it's not the esc ,this a good thing, can't help you with the twin setup though:-( , we will have to wait for kamikaze or anyone with dual mopeds setup to chip in |
07-25-2006, 11:24 AM | #13 |
gotcha
07-31-2006, 04:22 PM | #14 |
You just hook them up like my diagram shows. DO NOT cut the bec wire. They will work togeter to give you a total amp capacity of 6 Amps. Now turn on the tx and with wheels of the groung turn on both esc's. You need them both on to get both bec to work. THey will both run with only one on but you will only have a 3 amp bec. Now, program them just like you would if you only had one, because in all actuality the don't know that the other one is there. You basicly have to seperate systems, they just run of the same battery and of the same rx. I wouldn't run them off seperate batteries, I don't think it will hurt them, but it's a lot of extra weight, and you arent realy gaining anything by doing so. The will run fine off of one battery. Anyway I hope this helps. |
07-31-2006, 04:28 PM | #15 |
biger
07-31-2006, 04:48 PM | #16 |
thanks a lot , you the man!!
