Wiring Help\Question ESC,RX,Servo,BEC Need a little assurance here on my wiring just to give me piece of mind before I put power to it. I have a Tekin FXR set to 6v, Plugged into port 2 on the Futuba R2104GF, BEC (set to 6v) is wired to battery and powering the Hitec HS-7955TG with only ground and sensor wires going to RX port 1. I also have a Axial light controller plunged into port 3 on RX. Is this right and or am I safer wired like this. Just use BEC to power RX and just plug every thing into rx? |
Re: Wiring Help\Question ESC,RX,Servo,BEC You sound OK as is. If you choose to run the BEC into the RX, remove the red wire from the ESC/RX connector and cover it in tape. You do NOT want 2 power sources plugged into the RX. I prefer to run the BEC output direct to the servo and just run the signal wire to the RX. Some radios need the ground run to the RX (from the servo) as well to prevent radio glitches. |
Re: Wiring Help\Question ESC,RX,Servo,BEC Thank You for your reply. |
