12-27-2004, 12:00 PM | #1 |
Pebble Pounder Join Date: Jul 2004 Location: St.louis
| TQ3 and Tmaxx problem **FIXED**
ok so i bought a tmaxx and it ddnt come with a radio. so i went on ebay and bought a new tq3 controller for it and it can with new crystals and a new reciver box. Well i swapped crystals so the copntroller and the maxx have matching ones. so i turned it all on and tried to see what happened and nothing. when i turn the wheel on the control the truck doesnt turn its wheels. any ideas of what could be the problem?
12-27-2004, 12:17 PM | #2 |
Newbie Join Date: Apr 2004 Location: joliet il
| Re: TQ3 and Tmaxx problem
did u turn on the truck. theres a switch on the battery box that u have to turn on.
12-27-2004, 12:18 PM | #3 |
yes. the truck is turned on and so is the controller.
12-27-2004, 12:52 PM | #4 |
idk make sure the crastals r all the way in, make sure u got good batteries, check that the battery box is pluged into the reciver. thats all that i can think of the would be wrong with it
12-27-2004, 01:16 PM | #5 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
yeah, make sure all your batteries are good. then make sure the crystals are all the way in and are the same color( easy mistake). if that all checks out, its possible that the reciever is screwed. mine did the same thing once and a new reciever is like $26 at the LHS
12-27-2004, 01:18 PM | #6 |
well, i just reread it and i see you already had gotten a new reciever..just checkand make sure you dont have any broken wires and that everything is contacting real good...other than that, im kinda stumped.. sorry couldn't be more help :?
12-27-2004, 02:22 PM | #7 |
ok i will check that stuff all out. how should the channel buttons/switches on the bottom read out? for chan 1,2 and 3? should they all be the same direction??
12-27-2004, 02:41 PM | #8 |
Rock Crawler Join Date: Apr 2004 Location: North GA
Try swapping the crystals (one in RX to TX and vice versa). Their positions do matter. Also, in regard to the switches, it would get some kind of response no matter what position their in. Destroyer |
12-27-2004, 02:42 PM | #9 |
| Re: TQ3 and Tmaxx problem **FIXED**
ok i got it fixed. i went through and checked all the crystals and such and apparently on the TQ3 the crystals only fit in one way...i didnt know this so i turned it around and it works just fine now. thanks guys for your advise.
