Thread: wiring bec/servo/esc
Old 07-18-2012, 06:30 AM   #1
Default wiring bec/servo/esc
i have a savox 444.oz servo mmp esc and a ccbec what is the best way to wire them ! I have heard that if i wire it thru the rx it will frie it!
toby5240 is offline   Reply With Quote
Old 07-18-2012, 06:38 AM   #2
Default Re: wiring bec/servo/esc
CC BEC Wiring Diagram
AR Fabrication is offline   Reply With Quote
Old 07-18-2012, 06:47 AM   #3
It may work through the esc but I do not believe it will draw enough to work at its full potential.
Disconnect the power wire in the esc plug and tape it up, solder bec to your battery connector with the esc wires, plug everything up normally with the bec in the third slot on receiver
zkid009 is offline   Reply With Quote
Old 07-18-2012, 07:55 AM   #4
Originally Posted by AR Fabrication View Post
i dont think the rx can handel the constant volatage that the saxox needs
i have already fried one rx . i am just wondering is there a better way ?
Old 07-18-2012, 08:06 AM   #5
binaryterror's Avatar
Here is best way to wire BEC direct to the Servo.
question on BEC
Note: The ESC needs a red wire in the plug to power the Receiver now unlike the earlier posted image.
binaryterror is offline   Reply With Quote
Old 07-18-2012, 08:43 AM   #6
Proverbial threadkiller
Trubble's Avatar
I know at least three vendors here on RCC sell a bypass adapter. Costs $5-$6, plug in your servo, plug in your BEC, plug that whole apparatus into your receiver (steering channel), Bam. No pulling wires, taping anything off, and no worrying about the voltage to your receiver.
Trubble is offline   Reply With Quote
Old 07-18-2012, 09:05 AM   #7
Just installed one this week. Nice solution and an RCC vendor.
Receiver bypass adapter
CAIRN is offline   Reply With Quote
Old 07-18-2012, 11:54 AM   #8
I made mine so I could move it from rig to rig.
RusT808 is offline   Reply With Quote
Old 07-18-2012, 02:25 PM   #9
End result:
Old 07-18-2012, 02:31 PM   #10
ok thanks that is what i was looking for !
has this set up worked for other people ?
thanks this is what i am going to run ! THANKS TO VERYONE !!!!
i do like how you anunciate ! LOL
were did you get this Y- Harness
Old 07-18-2012, 02:46 PM   #11
"Y" harness is from my local hobby shop. I'm sure it's easily available online.
Old 05-03-2015, 08:02 PM   #12
You can get the "Y" harnesses from amazon- just type in "Futaba Y Harness"
caleb.cole is offline   Reply With Quote
Old 05-03-2015, 09:23 PM   #13
I notice the diagram linked in response #5 does not connect the negative from the xceiver to the BEC & servo whereas this one does. Not sure if it matters, but I did mine as listed here. Might cut down on some noise/interferance?
Cammmo is offline   Reply With Quote
Old 01-10-2016, 06:47 AM   #14
I'm in the process of doing the same thing. So I would wire this up as so, and plug the bec into the battery? Where does the esc plug into now?
samwise815 is offline   Reply With Quote
Old 01-10-2016, 03:01 PM   #15
Here is what i did.
I adjusted 4 BEC to 7.4v then sent them to Heyok so he could modify them to be "no brainer bec" with dual output. Perfect for servo and winches!
Here is how they came back:
End results are awesome! Plug and play at its finest!
Oldskoolcj is offline   Reply With Quote
Old 01-10-2016, 10:39 PM   #16
Trubble's Avatar
In the picture you posted, the Dean's connectors would go between the battery and ESC.
Just connect all the signal wires as they're labeled on that picture. Make sure you pull or cut the red wire on the connector that plugs into your receiver (in the steering port).
Then your ESC's signal wires would plug into the receiver in the ESC port (typically channel 2). You pulled the red wire out from the connector in the steering port, right? Then you do not pull or cut the red on your ESC's signal wires connector. Just plug your ESC into the receiver with all three wires intact.
Take your time, follow the picture you have up, and you should be fine.
wiring bec/servo/esc - Similar Threads
Wiring Help\Question ESC,RX,Servo,BEC mnickolson Electronics 2 06-27-2012 10:47 AM
Wiring Bec directly to servo xj_man_646 Newbie General 5 03-13-2010 02:18 PM
cc bec to servo wiring timo992001 Electronics 3 03-24-2009 08:53 PM
ESC / Servo / BEC Wiring Questions??? RCholic Electronics 1 09-18-2007 06:11 AM
