07-22-2012, 02:39 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| few problems with a AE-2 esc.. turnes on but no power to motor
turn it on. i get the tone. then the green light flashes. hit the throttle all it does is blink red.. no power to motor.. any ideas? thanks
07-22-2012, 04:46 PM | #2 |
| Re: few problems with a AE-2 esc.. turnes on but no power to motor
Try recalibrating, sounds like it isnt initializing fully because your neutral is off.
07-22-2012, 05:03 PM | #3 |
Newbie Join Date: Oct 2011 Location: Texas
I've had about the same problem with my Wraith. It ended up being the batt. connection not making good contact. I bent the contacts a little tighter and it worked fine after that. Sent from my iPhone using Tapatalk |
07-22-2012, 06:04 PM | #4 |
what do you mean neutral is off?
07-22-2012, 06:27 PM | #5 |
Rock Crawler Join Date: May 2009 Location: branchville
your neutral point is off. try and recalibrating it like the others said
07-22-2012, 07:12 PM | #6 |
From Driver's Ed guide (Castle) QUICK START GUIDE 4. Plug in the ESC Rx lead to CH2 on your receiver. 5. Make sure the ESC’s switch is off. 6. Plug in a battery. 7. Holding full throttle on your transmitter, turn the switch ON. A. After a few seconds you’ll hear multiple tones and the red LED will come on. B. Now hold full brake and after a few seconds you’ll hear multiple tones and the yellow LED will come on. C. Now relax to neutral and after a few seconds you’ll hear multiple tones and ALL the LEDs will light up. D. A few seconds later the ESC will arm with a double tone and you’re ready to go! |
07-22-2012, 07:34 PM | #7 |
ok thanks.. what do you do if it no long has a switch? was taken off.. i bought it this way
07-22-2012, 08:08 PM | #8 |
Just plug it in while holding full throttle.
07-23-2012, 08:13 AM | #9 |
thanks guys got it.. works good..
07-23-2012, 09:00 AM | #10 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
wow ill have to do this... thanks guys... yeah what i was going to say is i have an issue right now.. where mine was doing that.. i was told to make sure to center my throttle adjustment.. so i did and it wouldnt sync.. if i go all the way to one side. it will work... so mine is off calibration... |
07-23-2012, 09:05 AM | #11 |
WOW so easy and worked like a charm.. thanks guys...
07-23-2012, 09:19 AM | #12 |
yes it does.. didnt have any light tho since mine is waterproof now
few problems with a AE-2 esc.. turnes on but no power to motor - Similar Threads | ||||
Motor or esc problems | notmanywords | Electronics | 5 | 02-19-2012 07:08 PM |
Power consumption and ESC/Motor questions | Mocca Master | Electronics | 2 | 10-24-2010 01:18 PM |
need help motor or esc problems | millertime80 | Newbie General | 4 | 06-15-2010 01:56 PM |
ESC power problems PLEASE HELP!!! | Moondust1950 | Electronics | 11 | 10-29-2006 12:41 PM |
motor/esc problems | phillyb | Electronics | 2 | 12-13-2004 06:41 AM |
