07-23-2012, 09:06 AM | #1 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| fwd/reverse can get it to jitter
tough to explain but if i slow throttle it fwd or reverse it is fine... when i punch it sometimes it takes off and sometimes it will jitter.. rock jitter... same thing in reverse... any idea what could do that? on/off switch is cut out and soldered... motor wire is cut and soldered..... |
07-23-2012, 09:53 AM | #2 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| Re: fwd/reverse can get it to jitter
need more info. digital or FM? what components ?
07-23-2012, 04:15 PM | #3 |
| Re: fwd/reverse can get it to jitter +1. What battery (brand, LiPO?, how many cells/what voltage, what "C" rating, what connector) ESC, brand & model What motor, brand & model Brushed or brushless What rig You could have a low performance/old battery that can't supply enough power when you punch it. It could also be a poor pack connector. Heck, it could be a lot of things..... |
07-23-2012, 05:23 PM | #4 | |
| Re: fwd/reverse can get it to jitter Quote:
fare nuff u 2... no worries... so lets do this.. battery: ** not lipo ** dean plug ** 6 cell - nihm ** dont know stats... no name.. green cells with clear tape holding them together... ESC: ** Axial AX-2 with Deans plug Motor: ** Axial 27T - no bullets - soldered ** Brushed Rig: ** Axial AX-10 Scorpion (could have seen most of the specs in the sig ) ill do a video soon to show you.. rig will go fine... once going... it will spin tires up stuff too.... | |
07-23-2012, 06:19 PM | #5 |
albeit think i gotz it... the radio is screwed... stock scorpion radio... when i pull the trigger it drives.. i thought it was going slow after i soldered all connections... turns out if i squeeze the transmitter really tight... where the plastic sounds like it is gonna break.. it launches and has the speed i thought.... need a new radio... sheeze.. need new radio... lipos and charger... and im on vacation.. so no funds for that... |
07-23-2012, 07:36 PM | #6 |
OK, NiMH, they have decent punch if not failed. Connectors sound great. Yes, some of the specs are in your sig, I guess I'm to assume your question was for the rig in the sig?? As to the TX, maybe you can open the case up and clean the throttle pot. Some pots are sealed so cleaning is not an option. Was the rig faster before all the work? If so, did you check TX batteries? Did you try calibrating the ESC to the RX? |
fwd/reverse can get it to jitter - Similar Threads | ||||
Jitter Issues | kris1351 | Losi Micro-Rock Crawler | 9 | 12-11-2010 01:44 PM |
Rovers - better fwd or reverse tread | Rig Rocker | Tires and Wheels | 8 | 11-17-2010 01:30 PM |
servo jitter | jules | Losi Mini-Rock Crawler | 13 | 11-29-2008 04:49 PM |
popping noise fwd. to reverse | zack0620 | Tamiya CR-01 | 1 | 08-26-2008 03:04 PM |
Dig ?, 4wd-fwd-brake Or 4wd-fwd Only ? | twisted | General Crawlers | 2 | 01-12-2008 02:26 PM |
