07-23-2012, 09:43 AM | #1 |
Pebble Pounder Join Date: Nov 2011 Location: Livermore, Ca
| Futaba 9157s cuts out in a light bind
Ok so recently I've been starting to notice my futaba 9157s servo is cutting out in a small bind on my XR10 . My BEC is set to the max voltage the servo can handle of 6v. Has anyone els been having this issue? Also could this be caused by a battery with a low voltage? Kind of lost :(. any help is greatful . Thanks
07-23-2012, 10:03 AM | #2 |
| Re: Futaba 9157s cuts out in a light bind
List of electronics on my xr10 to help you guys troubleshoot. Futaba 9157s Tekin fxr New age dig Castle BEC Spektrum sr300 Gens ace 3s 1300mah 20c 11.1 v |
07-23-2012, 03:58 PM | #3 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Are you running the stock steering set up? My 9157 would stall all the time when running the stock steering. Upgraded to the vanquish parts and she is better. Still a lot of leverage on the servo though. I upgraded to see what it would do.. I like the servo, more power.. |
07-23-2012, 04:00 PM | #4 |
Does anything else die at the same time? How is the BEC connected....through the RX or direct to the servo? A 1300mah 20C seems a little light, I would prefer a higher "C" for the mah. It's not bad, just on the light side. Does the servo act the same on different packs? What pack connectors (Deans, Traxxis, Tamiya, etc....)? |
07-23-2012, 10:13 PM | #5 | |
| Re: Futaba 9157s cuts out in a light bind Quote:
07-23-2012, 10:24 PM | #6 | |
05-13-2013, 04:58 AM | #7 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
Sorry to dig up the dead but my s9157 is having the same problems. I'm running a similar set up on my scx10. Seems like sometimes when I'm at full turn the servo will get stuck when there is a light bind. It only happens sometimes. A few times when it happened I picked up the truck and held the tire by hand and tried to turn the opposite way. It feels like there is no power. Anyone have any advise for a fix? Last edited by cox308; 05-13-2013 at 05:06 AM. |
05-13-2013, 06:36 AM | #8 |
| Re: Futaba 9157s cuts out in a light bind |
05-13-2013, 03:30 PM | #9 |
05-13-2013, 04:00 PM | #10 |
| Re: Futaba 9157s cuts out in a light bind This servo seems OK based on specs (it's a s9157)... TowerHobbies.com | Futaba S9157 Digital High-Torque Servo Overall I prefer HiTec (7950's in most of our rigs), but I do have 1 Futaba (BLS157HV) that is pretty wicked. Have you checked your steering EPA's? If you try to overdrive the servo it can lead to brownouts even with an external BEC. |
05-14-2013, 05:41 PM | #11 | |
Anyways...I have figured out my steering problem and it was not the servo, its the steering geometry itself. It turn out it is turning too much and going over center and with the slightest bind it would get stuck. | |
Futaba 9157s cuts out in a light bind - Similar Threads | ||||
Futaba R614FF won't bind to 4PL | JimmyJam | Electronics | 2 | 03-03-2012 12:36 AM |
Losi Spectrum 2.4 transmitter bind to Futaba? | acrosteve | Electronics | 3 | 05-03-2011 09:18 AM |
TX bind light won't come on now? | GSRswapandslow | Losi Micro-Rock Crawler | 10 | 01-22-2010 04:03 AM |
Night crawler cuts power to motor under bind? | Huss666 | Team Losi Comp Crawler | 9 | 11-16-2009 01:51 AM |
Futaba 3pm 2.4 bind Question | Mr. Ed | Electronics | 4 | 07-14-2009 10:47 AM |
