07-28-2012, 08:40 PM | #1 |
Newbie Join Date: Oct 2011 Location: Rainy Pacific NW
| Steering servo help..
I just bought my first scale crawler today. It's custom built and I'm not exactly sure what steering servo it has, but it has the scx-10 transmission on a Tamiya high lift body... So I was out crawling over a stump and flipped it over backwards and landed on its top. Now the steering only turns one way. Or it wants to lock to one side.. So my question is, did I break something? Or is there a way to adjust the alignment or something? Thanks for any info guys. I can't wait to get it back up and going. What little time I played with it today was excellent!!
07-28-2012, 10:47 PM | #2 |
| Re: Steering servo help..
I would disconnect the servo arm from the rest of the steering and see what the servo does when "steering it" with the radio. You may have stripped off some teeth from one or more gears. |
07-28-2012, 11:33 PM | #3 |
Thanks Charlie. I disconnected everything and it works as it should. So that means I need to replace it right? It's plasti-dipped so I can't tell if it's a good servo or just a cheap one. Either way I got it for a song and a dance so I'm not complaining.
07-29-2012, 11:54 AM | #4 | |
RCC Addict Join Date: Jul 2011 Location: Orlando
| Re: Steering servo help.. Quote:
Good luck, I think I just fried a 100 dollar servo (Savox 1268SG) wont work at all. Damn thing. | |
07-29-2012, 12:04 PM | #5 | |
I would also check the linkage itself, you may be having a bind developing. I would also double check the steering EPA's so you are not overworking the servo, that's a fast way to kill one. Are you running an external BEC? My rule of thumb is you really want one (most of us use a Castle Creations 10A BEC) when you hit ~200inoz. | |
07-29-2012, 06:25 PM | #6 |
It was a stripped steering horn. Replaced it with a metal one and shes doing great. Thanks for the help guys.
07-29-2012, 10:38 PM | #7 | |
What horn/arm did you use? As a cheapie, I use & recommend the GH Racing clamping ones. They are also known as Golden Horizons. Robitronics & Imex (?) are top of the line, but cost more. | |
07-30-2012, 01:01 AM | #8 |
Awesome. When this one wears out (or I break it lol) I will look in to that. I do believe this ones made by Hot bodies. It's all aluminum and was 7 bones after tax. Not sure if that's good or not? Lol. But I'm just stoked to have it going again. Now I'm reading up on batteries. It came with 2 Lipos but no charger. So I'm not sure if I want to spend more on a charger and stick with Lipos, or just switch to the cheaper Nimh or whatever those other ones are... I'll probably stick with Lipos but we shall see.
07-30-2012, 04:28 AM | #9 |
Stick with LiPO........you can get a decent charger for low $$. Just search for "charger", lots of recent replies. |
07-30-2012, 12:53 PM | #10 |
+1 on going with LiPos. Stay with them and get a quality charger. Charger is one of the items I wouldn't skimp on. Sent from my Samsung Galaxy Note (Phablet) |
07-30-2012, 01:08 PM | #11 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
dont bother with NiMh!!! i am currently using a 7.2v 3300MaH and it hardly moves my vxl3s at all! waste, go LiPo, i will be!! |
07-30-2012, 01:53 PM | #12 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
I have a similar question....well....it's at least related to servos and non-momvement. Currently running a Hitec HS5995TG wired directly to a CCBEC that's set to output @ 7V. Also running the RTR Wraith ESC (AE-2) and a 7.4V 5000mah 2S Lipo. Every now and then, sometimes more often than not, my steering stops working, almost like it's overheating. I have had issues lately with my motor getting hot because of a bind somewhere in the drivetrain, so is it possible that the motor has been taking most of the voltage from the battery, not leaving enough to run through the BEC to the servo? Is it possible I need to run an 11.1V battery as opposed to a 7.4V? I'm at a loss for what's going on with my servo, as it usually happens at times when I really need my steering.
07-30-2012, 05:58 PM | #13 |
Sticking with the Lipo for sure. Prices aren't that bad at all. You guys rock. Thanks a heap.
Steering servo help.. - Similar Threads | ||||
Steering Servo/Dig Servo Questions | YJJPWrangler | Electronics | 5 | 02-02-2011 10:59 PM |
Mamba max, 11.1 1350 mil 25c, 5955tg steering servo, 5645mg dig servo | BEAU | Electronics | 5 | 01-21-2009 02:36 PM |
steering servo help | maxxrookie | Newbie General | 5 | 07-11-2008 06:37 AM |
