View Poll Results: How does your receiver look... | |||
Plugs on top - Channel numbering from bottom up | 11 | 78.57% | |
Plugs on top - Channel numbering from top down | 1 | 7.14% | |
Side entry - Channel numbering from top down | 0 | 0% | |
Side entry - Channel numbering from bottom up | 0 | 0% | |
Other | 2 | 14.29% | |
Voters: 14. You may not vote on this poll |
07-29-2012, 03:58 AM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
| Tziworld BEC-RX Adapter - Your Input required
Hi all... I'm designing a new product to simplify the wiring of a BEC into your receiver whilst still retaining all ESC wiring in place. No more messy wires, no more adapters, and no more disconnecting the red wire from your ESC. Just plug and play. To make this product compatible with the most amount of receivers, I'm after some feedback as to what type of receivers people use. While researching I have noticed that some receivers have a "backwards" numbering on the channels and count from the top down rather than bottom up. Please post up the model of your radio receiver and if possible post a picture of the pin configuration with the pin-labels visible just like the examples below. Thanks in advance for your help on this. Last edited by Tzi; 07-29-2012 at 04:22 AM. |
07-29-2012, 04:32 AM | #2 |
Rock Stacker Join Date: Mar 2009 Location: The Land Downunder
| Re: Tziworld BEC-RX Adapter - Your Input required
Spektrum AR6100, and the Orange RX (the cheap hobby king ones). Sorry no pics yet.
07-29-2012, 04:36 AM | #3 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
RC4WD xr4
07-29-2012, 08:07 AM | #5 |
I run a hacked GT3B and a Futaba 3PM-x. Both are out the top and bottom-up as in the 1st RX picture you have. Now, I do my own "no solder" way to connect the BEC to the servo, thus I am not in the market for an adapter you are working on. |
07-29-2012, 10:00 AM | #6 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
I think this product you are designing is covered already. You have this Receiver bypass adapter or No Brainer BEC Just incase you didn't know about these. |
07-29-2012, 01:31 PM | #7 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
I have the FLy SkY 3 Ch one man. and i voted. look forward to seeing this.
07-29-2012, 03:29 PM | #8 |
I am aware of those existing products... but my new product will be substantially different. I just didn't want to give too much away yet. I currently have about 100 in stock of the battery man bypass adapter and they are just not a big seller for me. I have given away more than I sell. Brilliant product, but maybe the market is different in Australia. Last edited by Tzi; 07-29-2012 at 05:43 PM. |
07-30-2012, 06:45 PM | #9 |
One of the biggest RC forums on the net, and in two days I only get 5 responses to a simple request... I dont get it. Did I post this in the wrong section? |
07-31-2012, 11:40 PM | #10 |
Quarry Creeper Join Date: Aug 2011 Location: Spalding, Lincs, UK
I use stock axial rx's and Acoms dr224's, both are top loaders with batt at the top then 1,2 and 3 descending.
08-01-2012, 01:09 PM | #11 |
I think maybe you need to give some more info on this new product. I have a HeyOK bec for dummies even thou I can solider. Makes for quick work checking servos and other stuff. I also do use it in 1 of my rigs but can be pulled at anytime I need to check something else out. I am all for new and improved products but I think with the discription you have given most are seeing it as already covered. BTW I run mostly futaba 4pl receivers. |
08-01-2012, 04:59 PM | #12 |
If I was producing a new design 1.9 tyre would people tell me "don't bother, there's already tyres on the market" ? I am well aware of the other products on the market - I even stock them! I was just asking for some feedback as to what receivers people use, so as to make sure my (new and unique) product is suitable to the most amount of the market. Last edited by Tzi; 08-01-2012 at 06:22 PM. |
08-02-2012, 12:57 AM | #13 |
Oops, sorry, the axial RX is Batt, ch3, throttle and then steering.
08-02-2012, 03:43 AM | #14 |
| Re: Tziworld BEC-RX Adapter - Your Input required |
08-02-2012, 03:46 AM | #15 |
| Re: Tziworld BEC-RX Adapter - Your Input required And the winner is...... Plugs on top - Channel numbering from bottom up It seems as though this is the most common configuration, so I'll start with that and produce another model later |
Tziworld BEC-RX Adapter - Your Input required - Similar Threads | ||||
Tziworld Beefy Winch Controller - Now With Video!!! | Tzi | Vendors Electronics | 42 | 09-07-2014 05:29 PM |
New Tziworld Winch | Tzi | General Crawlers | 37 | 09-25-2013 11:44 AM |
New Tziworld Winch | Tzi | Electronics | 35 | 09-23-2013 10:04 PM |
*** GIVEAWAY *** Tziworld Beefy Winch Controller Giveaway... 2 Chances to win!! | Tzi | General Crawlers | 67 | 07-21-2012 10:26 AM |
2 mmpros, bec, adapter walk into a bar... | Deezul | Electronics | 5 | 01-28-2011 10:01 PM |
