07-29-2012, 12:33 PM | #1 |
| Servo wired directly to a TX
Is there any way to wire up a servo so that it is hard-wired to the TX?
07-29-2012, 12:39 PM | #2 |
| Re: Servo wired directly to a TX
Just wiring it up??? I highly doubt it. You will likely need a way to convert the TX signal to something the servo understands. You also need to supply power to the servo. Actually, you can do almost anything, but is the potential cost worth it?? Curious, why do you want to do this?? |
07-29-2012, 12:46 PM | #3 |
I am making a pole-mount for my GoPro that I can rotate. I can wire up a cheap TX/RX combo with batteries at both ends, but I am trying to keep the weight down, keep the wiring to a minimum and use as few batteries as possible. I do have a couple of old TRX AM radios, what would happen if I soldered the RX antenna directly to the the TX's antenna output? |
07-29-2012, 12:50 PM | #4 | |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
| Re: Servo wired directly to a TX Quote:
07-29-2012, 02:58 PM | #5 | |
No reason you couldn't use a cheap battery to power the RX and plug in a cheap servo to do the rotation.. | |
07-29-2012, 06:52 PM | #6 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
| Re: Servo wired directly to a TX Thats just gold! Yep, you can do it using a servo-tester. That way batteries would be only be needed at one end. HobbyKing R/C Hobby Store : Servos and parts>Servo Tester You could use the cheapest one and put it in a nice box with a knob for easy use. HobbyKing R/C Hobby Store : Simple Servo Tester Last edited by Tzi; 07-29-2012 at 06:57 PM. |
07-29-2012, 07:24 PM | #7 | |
Thanks! | |
07-29-2012, 07:29 PM | #8 |
Your welcome. |
Servo wired directly to a TX - Similar Threads | ||||
Servo directly to battery | papabash | Losi Mini-Rock Crawler | 9 | 12-08-2011 02:51 PM |
Direct wired servo goes wacky? | Deezul | Electronics | 2 | 01-06-2011 04:29 AM |
Wiring Bec directly to servo | xj_man_646 | Newbie General | 5 | 03-13-2010 02:18 PM |
cc bec wired to just 1 servo | vdubman | Electronics | 7 | 02-10-2009 08:48 PM |
Powering 5995 robot servo directly from Super Rooster | kevinlongisland | Electronics | 6 | 01-20-2006 08:46 PM |
