07-30-2012, 04:31 PM | #1 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| heli lipo in car
ok i didnt know what to search for so didnt get far.. so my stupidiness has to come out.. i gotz 2 x EFLB80990 batteries from my heli i dont use.. they are 2S lipo... could i put a deans on it and run it in my truck? were talking 800mah 2s.. lemme know if that is a bad idea.... |
07-30-2012, 04:43 PM | #2 |
| Re: heli lipo in car
They should be fine, voltage is voltage regardless of the source. The only issue you may have is the lower discharge (IR) of those compared to the higher "C ratings" of other packs. However your run time may only be a few minutes depending on your motor and gearing.
07-30-2012, 07:51 PM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: Gresham, OR
It's not a bad idea. They will put out the same voltage as any other 2s, it's really a matter of what C rating they are, anything over 20 should be fine. Under 20 may work also, but I have not used any that low before.
07-30-2012, 08:08 PM | #4 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
2s to 6s in my helis and my cars/trucks. It dont care what you hook it too.
07-31-2012, 03:22 PM | #5 |
Based on the other eflite batteries those are probably 20c. With the 27t motor and AE-2 you should be ok. If you do get in a bind you could pull close to the limit. I say run them a few times being a bit careful and you should be good.
heli lipo in car - Similar Threads | ||||
Sub Micro Heli Fans - New From CowRC: The Sub Micro Heli Pad/Mat | The Cow | Non Crawler RC's | 2 | 05-08-2010 08:41 AM |
Quark pro car 22a/33a with 5s lipo? | crawled | Electronics | 7 | 08-28-2007 06:37 AM |
