08-01-2012, 12:24 AM | #1 |
Newbie Join Date: Aug 2012 Location: us
| ways to waterproof a LED
Hi All. I'm working on building a light bar to go inside the bed of my friends truck bed and need to find a way to make the led light bulbs, or at least water resistant. I know the LEDSupply sells LED Seal, but i'm not 100% sold on it. Basically i am going to be using a 5 ft aluminum, 3 XP-g's on stars, and the LEDSupply 1400mA BuckBlock ( which is waterproof). I'll be building 1 bar for each side of the truck so it will be plenty bright! For waterproofing, i was thinking of just putting a coating of clear RTV Silicone on top of the Flexible LED Strip Lights, but not sure if they can take the direct heat of the LED. I know the silicone would disperse the light but that would actually be better anyways. Any other ideas on how to make the led strip water resistant or waterproof? |
08-01-2012, 02:38 AM | #2 |
Newbie Join Date: Jul 2012 Location: New Zealand
| Re: ways to waterproof a LED
LED's are resonably waterproof, although silicone on the exposed metal, and heatshrink an any wiring will be the ticket. As for the heat, LED's don't produce much at all, some none at all. I assume the rest of the vehicle is waterproofed, so the LED's should be fine. I have some totally untouched, in a fish tank. As long as the wiring is 'proofed, you'll be fine man.
08-01-2012, 09:31 AM | #3 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
Heat shrink and be done. LEDs are not bulbs, they are light emitting diodes, a diode in cased in a clear acrylic cast, no water or air can get in. you are looking at what .3 volts of power, not enough to short.
08-01-2012, 09:55 AM | #4 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
hot glue..hold's em in and h20 proof to boot. Drail
ways to waterproof a LED - Similar Threads | ||||
How to waterproof your AE2 ESC, AR2 Receiver and LED light board. | noremacyug | Electronics | 9 | 07-09-2013 11:54 AM |
