07-31-2012, 05:43 PM | #1 |
Rock Stacker Join Date: Jul 2012 Location: nor cal
| tekin fxr is silent
my fxr seems to work but doesnt chime and never has ive only run two packs through it and all seems well.Should i be concerned?
07-31-2012, 05:53 PM | #2 |
| Re: tekin fxr is silent
The ESC does not make a sound, it's the motor that it's hooked up to. What motor, what condition is it, when did you last check the comm & brushes??
07-31-2012, 08:57 PM | #3 | |
Rock Crawler Join Date: Dec 2008 Location: Displacement
| Re: tekin fxr is silent Quote:
Do you actually own one? | |
08-01-2012, 08:32 AM | #4 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: tekin fxr is silent He is right, the ESC does not make the chime, the windings in the motor do as they are pulsed by the ESC. Normally if they don't chime, they don't drive the motor. Curious as to how many have seen this?
08-01-2012, 08:49 AM | #5 |
Rock Crawler Join Date: Dec 2009 Location: Redding
Hey Ty, mine started to do it after running for 3 hours in 100 degree weather. I suspect it has to do with the motor. At times I would pull the throtle and get nothing, then had to push the rig to manually start the motor moving then the rig would go. I don't know about motors yet but I'm guessing I need to change the brushes on mine.
08-01-2012, 08:55 AM | #6 | |
RCC Addict Join Date: Jun 2006 Location: hillsborough
Most likely your motor will need a good rebuilding, comm cut and brushes replaced. What kind and brand of motor? | |
08-01-2012, 09:19 AM | #7 | |
Are you saying that they sense feedback from a motor before they are armed? Just to be clear, are we talking about the arming chime or the motor noise when creeping? | |
08-01-2012, 09:47 AM | #8 |
The chimes are made by the motor, the ESC pulses the motor really fast and it makes noise. I wonder how long it took to get the chime right, had to be some trial and error there. Also if you swap to a different motor (different brand or turn) you will be able to tell the difference in the sound it makes. |
08-01-2012, 07:29 PM | #9 |
| Re: tekin fxr is silent |
08-01-2012, 10:54 PM | #10 |
| Re: tekin fxr is silent Touche. I guess I'm still not understanding how you and Ty can say that its not the esc chiming. But when you turn them on the chime is clearly coming from the esc. Granted I can understand that it only makes this sound when it senses that a motor is hooked up. But it not making a sound and still working just fine is contradicting to what should be happening as Ty@tekin said about no sound no work. I wasn't concerned before, but now I'm curious. |
08-01-2012, 11:00 PM | #11 |
RCC Addict Join Date: Jun 2010 Location: Australia NSW
the motor windings act like a speaker against the magnet, so when you turn on the esc, it uses the motor like a speaker and bleeps or whatever it does (i dont have a tekin, but every ESC ive had does the same thing each in a different way) if theres no motor attatched, it wont beep. so if the motor is attatched, and still not beeping. either the ESC has cacked it, or the motor has. unless of course, there is a way to turn the beep off on the tekin. (not that i know why you would want that...) edit: the wierd part is, you say it still works. so you lost me on that part. edit2: if your interested, try hooking a motor to an amplifier. you will hear music. just dont crank it up, motors tend not to like AC power.... Last edited by klampykixx; 08-01-2012 at 11:02 PM. |
08-02-2012, 10:16 AM | #12 |
+1 The chime pulse comes from the ESC, yes, but the actual sound comes from the motor windings. |
08-02-2012, 11:46 AM | #13 |
Now you guys have me wanting to turn on my scaler and listen to where the chime is coming from! I would have sworn the noises came from the ESC.
08-03-2012, 04:33 AM | #14 | |
I can understand your concern about not hearing the chime, but I wouldn't worry about it if it appears to be working. You may have worn brushes, low brush spring tension, etc. That may explain the "no chime". Hope that helps. I'm not trying to come off as a PITA, but it happens anyway...... | |
08-03-2012, 06:46 AM | #15 |
Having been using Tekin products since almost forever I have found that some motors are loud and some are quiet and a few almost make no noise at all.
08-03-2012, 09:24 AM | #16 | |
Klampykixx answered my question about the motor actually making the sound. An explanation of this is all I was after. As for the one that is silent or too quite to hear I believe might just be low spring tension. I did go through a few and noticed a sound level difference. | |
tekin fxr is silent - Similar Threads | ||||
Mamba Max , Tekin FXR or Tekin FXR PRO? | TheHeadHunter | Electronics | 21 | 06-21-2012 08:15 AM |
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
