08-02-2012, 08:00 PM | #1 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Hyperion Servo
I hope being cheap doesn't come back to bite me again. I picked up a Hyperion DH20-UTD servo. The specs are pretty good, 292oz/in @6V and 333 @7.4 and the price was respectable at less than $50 The build quality looks to be pretty nice. I'll give it a run this weekend and report back. I will be running it at 6V right now because I don't feel like ripping the truck apart and setting up a Windows computer to change the BEC. I searched on here and didn't find much info about these so I may be the guinea pig. |
08-02-2012, 08:47 PM | #2 |
Rock Stacker Join Date: Nov 2011 Location: Summerville SC
| Re: Hyperion Servo
Definitely let us know! With the torque ratings, is it metal geared? Have you found gear kits for it yet to be able to rebuild it if necessary?
08-02-2012, 09:10 PM | #3 |
| Re: Hyperion Servo
It is titanium geared and they have gear sets available. Hyperion Catalog |
08-03-2012, 07:59 AM | #4 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| Re: Hyperion Servo
Here is the most impressive spec I found on this servo and haven't seen on any other manufacture's specs Maximum input voltage Loaded or unloaded input voltage should never exceed 8.4V Hook a 2s up straight to it!!! Very nice!!! Looks to be a good servo!!! |
08-03-2012, 09:35 AM | #5 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: Hyperion Servo
i run a solar servo, and a hobbyking servo strait off my main 2s pack
08-05-2012, 06:02 PM | #6 |
| Re: Hyperion Servo
Went out today and it did pretty well. It won't wag the back of the truck around, but my rig is a bit portly. I am going to bump the BEC to 7.4 and see how that goes. It isn't nearly as noisy as the Hobbico at rest, but under load it does make some noise. So far, for the money, . I won't be convincing any Hitec die-hards anytime soon though. |
08-06-2012, 12:38 PM | #7 |
| Re: Hyperion Servo
I'm a hitec guy and sounds like a great replacement for the 7955. Similar specs with titanium gears for less then half price!!! Keep us posted on how this servo is working out for ya!!!
11-27-2012, 12:29 PM | #8 |
| Re: Hyperion Servo
Long term update. I have come to the conclusion that this servo is better left at the LHS. I have put it through it's paces and it just doesn't work very well anymore. I am running it at 7.4 Volts and there is no way it is putting out 333oz of torque. It won't even get back to center a lot of times with out blipping the throttle to fully unload it. It's been quite hot a few times but ultimately not anymore abused than my stock axial servo that still works but is just a bit weak. In the end, I'm biting the bullet and getting a Hitec 7954SH. |
11-27-2012, 04:07 PM | #9 |
Quarry Creeper Join Date: Feb 2012 Location: AZ
| Re: Hyperion Servo I'm also in the market for a better servo and I'm torn between the 7954SH and the Savox SA-1231SG. The Savox has higher torque ratings but I've never owned Savox and I'm unsure. I hear they're nice quality. Price between the two is almost a wash.
11-27-2012, 07:09 PM | #10 |
| Re: Hyperion Servo
Savox are supposed to be good quality. I've heard good things about Hitec customer service and warranty work. One of our trail guys used a Savox 1256 (I think) and it worked well but it was a buzzy little b@$tard. I've read other places that they tend to be noisy servos.
11-28-2012, 12:43 PM | #11 |
RCC Addict Join Date: Jul 2011 Location: Orlando
If the specs and price are the same or a wash..... Go with the HiTec. My Savox are good but very noisy and very power hungry. HiTec seems to have a long track record. Sent from my Samsung Galaxy Note (Phablet) |
11-28-2012, 06:39 PM | #12 | |
Quarry Creeper Join Date: Dec 2008 Location: Australia
| Re: Hyperion Servo Quote:
Hyperion rate their servos for Dynamic (physical) Torque and Holding Torque, both very different. It is rated to 333oz for holding torque and 166oz dynamic torque about half. So you were the first and the last??? | |
12-18-2012, 04:22 PM | #13 | |
Pebble Pounder Join Date: Oct 2012 Location: Shreveport
sent using a string and an empty beer can | |
12-19-2012, 06:00 AM | #14 | |
Sitting on the ground, a digital servo can buzz as it tries to find "center", this is common on lots of servos regardless of brand. | |
12-19-2012, 09:08 AM | #15 | |
Sent from my Samsung Galaxy Note (Phablet) | |
12-20-2012, 08:11 AM | #16 | |
12-20-2012, 09:28 AM | #17 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Hyperion Servo
All i buy are hitec servos, been very happy with them but the 7954 was the only one that I've had that failed prematurely. It had a bad board and then the gears stripped out. Hitec fixed it for free both times but considering how many people have had problems with it I would recommend getting something else.
12-20-2012, 10:37 AM | #18 |
I'll probably go with them next time sent using a string and an empty beer can |
Hyperion Servo - Similar Threads | ||||
Hyperion Atlas DS 16 metal servo | fishh8me | Losi Mini-Rock Crawler | 8 | 01-01-2013 03:26 PM |
Hyperion servo | Jew1028 | Electronics | 0 | 03-10-2012 02:50 PM |
hyperion 5i? | jimbiss | Electronics | 1 | 04-24-2009 07:28 PM |
