08-05-2012, 09:45 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Roanoke, Va
| Best Split pack battery to buy..
Hi there, I would like to buy the best bang for the buck split pack batteries. I current have a 8 cell nicd with a tamyima plug and 1500 mah that i bought from TCS crawler. I was wondering what the best one I can buy and what Mah I should run and would like to stay with my old style plug. |
08-06-2012, 04:58 AM | #2 |
| Re: Best Split pack battery to buy..
Knowing the rig, ESC, motors & your current use would help. I thiunk most of us would recommend going to LiPO since they are smaller & lighter than NiCD/NiMH. None of us would recommend staying with the Tamiya plugs, they WILL cause issues down the road. I would check out www.CheapBatteryPacks.com for choices. I only buy from them. |
08-06-2012, 05:16 AM | #3 |
Rock Crawler Join Date: Mar 2011 Location: hampton
i run 5700 mah 2 cell lipo saddle packs in my scx10. i get 2 hours run time out of it.if my truck was lighter it would run longer. i get my batteries from hobbyking.com U.S warehouse. X2 on the tamiya plugs. they will cause you all kind of problems |
08-06-2012, 07:56 AM | #4 |
Well, I'm still on stock axail electronics. It haven't crapped out on me yet but I do noticed some twitching on its own.
08-06-2012, 08:30 AM | #5 | |
| Re: Best Split pack battery to buy.. Quote:
As for ordering packs, cheapbatterypacks.com would probably be my first recommendation. You can order whatever configuration and connector you need. | |
08-06-2012, 12:55 PM | #6 | |
08-06-2012, 06:37 PM | #7 |
| Re: Best Split pack battery to buy.. |
08-06-2012, 11:23 PM | #8 |
I didn't try a glitch buster because I really didn't think it would work. I run my BEC through the receiver, and pull the red wire on the ESC's connector. There are also bypass adapters that let you run the BEC to the servo, and the ESC continues to power the receiver, all plug and play, no pulling red wires. The BEC's power wires I just soldered onto the blades of my Traxxas battery connectors. |
08-07-2012, 05:18 AM | #9 | |
08-07-2012, 08:23 AM | #10 |
If you're looking for one that totally and completely plug and play, the one I've seen was buried deep within a thread somewhere. Since I can solder well enough, it wasn't something I needed, so no reason to bookmark the thread. Can't help you on that one. Wouldn't matter, it used Deans connectors anyway. If you're going to have to change to Deans, might as well just solder it right onto that. As far as the bypass adapters I mentioned, I've seen them on both Holmes Hobbies and CreationFab websites. But those are just on the output end of the BEC, doesn't get you around soldering the input end. |
08-07-2012, 08:39 AM | #11 |
RCC Addict Join Date: Apr 2008 Location: Georgia
I think rc4wd and maybe EBay have a plug and play deans connector for a BEC. It's only plug and play if you have Deans to begin with. Trash those tamiya plugs first, and then you'll be on the right track. |
08-07-2012, 10:22 AM | #12 |
| Re: Best Split pack battery to buy.. Btw, I love your sig, very true. Anyway, I'm shopping for deans connectors.
08-07-2012, 10:27 AM | #13 |
| Re: Best Split pack battery to buy.. Thanks, and remember if you can't tackle soldering right now but need the deans sooner, someone in your area may be able to help. Your local hobby shop may help as well, if you have one.
08-07-2012, 10:30 AM | #14 |
| Re: Best Split pack battery to buy.. I have a hobby shop but don't really carry what I need. Who should I shop for deans?
08-07-2012, 03:17 PM | #15 |
| Re: Best Split pack battery to buy.. There are lots of shops (brick & online) that carry Deans. I use Tower Hobbies for a lot of general stuff. If there are other crawlers in your area, maybe, as a group, you can talk your LHS into carrying more crawler stuff. My son & I did that, we also let our local club know the LHS is carrying more stuff so it works both ways. |
08-07-2012, 05:39 PM | #16 |
What would i have to do with the plug for my charger?
08-07-2012, 06:53 PM | #17 |
08-07-2012, 07:42 PM | #18 |
I just figure ask, rather be safe than sorry. Also I thought maybe the charger may be senstive or something.
Best Split pack battery to buy.. - Similar Threads | ||||
split battery pack question | barbaricboye | Newbie General | 3 | 09-28-2008 06:03 PM |
6 cell Split Battery Pack | kevin999 | Newbie General | 4 | 02-10-2008 08:13 PM |
Tech: Building a split 4 or split 3 2/3A battery pack | Grizzly4x4 | Electronics | 15 | 09-19-2007 08:37 PM |
