08-10-2012, 01:52 PM | #1 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Lurching
So I just recieved a losi mini crawler and it has a cc bec, sidewinder micro, holmes motor, and a hitec 5645 I think it is. I tried updating the software to the new 1.32 version and it started lurching back and forth. Kinda like I was switching between fwd and rev real quick. I put it back to the 1.22 version that it was originaly at and now it works fine. I want to have the up to date software but I don't know if it'll work. Why do you think it did this? |
08-10-2012, 01:55 PM | #2 |
| Re: Lurching
Sounds like it is in brushless mode.
08-10-2012, 02:17 PM | #3 |
| Re: Lurching
Hmm. I'll update it again and charge a battery and then go through the settings. Do the settings reset when you update the software?
08-10-2012, 03:30 PM | #4 |
| Re: Lurching
Sometimes they reset
08-10-2012, 04:34 PM | #5 |
| Re: Lurching
Alright, new problem, the esc gets power and lights up. But, it won't move. The motor got really hot during the test run. I think 3s was to much. I think it's a holmes torque master pro mini. It's blue and says torquemaster.
08-10-2012, 05:48 PM | #6 | |
| Re: Lurching Quote:
It's always the 1st thing I suggest. | |
08-10-2012, 10:15 PM | #7 |
| Re: Lurching
Yup, the esc is fine, it lights up like normal. But, no little start up chime. I think it's the motor, gonna send it in to holmes when I get the chance and have it rebuilt. Steering's fine, esc lights up like normal, batt & reciver work fine, bec works, only thing left is the motor. Doesn't the start up chime come from the motor? I could've sworn it said that in the manual.
08-11-2012, 05:58 AM | #8 | |
| Re: Lurching Quote:
No sounds could just be that motor, loose brush spring tension, etc. I would try disconnecting the motor from the ESC and try running it direct of a battery pack. | |
08-11-2012, 02:40 PM | #9 |
| Re: Lurching
I'm going to send it in and just have it rebuilt/fixed. I have to much stuff going on right now and its just easier. The motor shaft won't move unless I grab some plyers and put some force into turning it. And I just got the truck too. |
Lurching - Similar Threads | ||||
Brushless motor lurching | Timberline | Team Losi Comp Crawler | 11 | 06-18-2011 12:54 PM |
Lurching. Have an idea as to whats the cause but would like to confirm | recover1227 | Newbie General | 5 | 04-12-2010 11:27 AM |
Went from Crawling to Lurching and Surging | RickM | Axial AX-10 Scorpion | 10 | 02-10-2010 10:03 PM |
Downhill lurching | Iberian | Team Losi Comp Crawler | 17 | 02-01-2010 11:36 AM |
Problem with Lurching | Marc M | General Crawlers | 14 | 08-16-2007 09:50 PM |
