08-15-2012, 10:58 PM | #1 |
Pebble Pounder Join Date: Aug 2012 Location: repentigny qc
| tekin rx8 or mmp
im building a wraith il use the tekin pro4 motor and i was wondering whitch esc to use rx8 from tekin or mmp ? im new in electric but i want a gd set right away ;) so what the difference betwen both and y 1 would be better thx i have see couple of ppl burning the mmp thats y im asking this |
08-15-2012, 11:38 PM | #2 |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
| Re: tekin rx8 or mmp
If your running a Pro4 motor then go the RX8 hey, youl have no problems with that setup and it will be super quick hey...
08-15-2012, 11:42 PM | #3 |
| Re: tekin rx8 or mmp |
08-16-2012, 02:39 AM | #4 |
Rock Stacker Join Date: May 2010 Location: Boise
You can cut the plastic fan shroud off, just leaving the four plastic pieces that capture the heat sink. That reduces the size quite a bit, and the RX8 will run a 3300 on 3s all day with no fan. Due to size constraints in my rig, I'm going to try an RS Pro. If you can fit it, the RX8 will be perfectly suited and super reliable. 5 amp BEC too will run a decent servo if you're not running an insane torque monster. |
08-16-2012, 02:42 AM | #5 |
Run a decent servo without an external BEC I mean. An external is recommended for anything over 280oz or so of torque, or if you're running accessories like a bunch of LED's or a winch.
08-16-2012, 04:44 PM | #6 |
thx for help guys i apreciate since its my first wraith i want to do it right |
08-16-2012, 05:11 PM | #7 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Obviously if money is no concern then the RX8 will be great. I have 2 Castle MMP's and have no issues with them at all. But prices are a bit different I believe, I got my MMP for 105 and I think the RX8's are 200+ (I could be wrong though)
08-16-2012, 05:37 PM | #8 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Tekin RS Pro.
08-16-2012, 05:44 PM | #9 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
08-16-2012, 05:52 PM | #10 |
Hoping it'll do okay on 3s to a 3300, but that'll probably be pushing it. Will be 90% trails so I'm hopeful. Have an extra temp sensor coming for the mt4 to monitor it. Ty thought it'd be fine on 2s, and I won't be using the internal bec fort anything. Sent from my MB860 using Tapatalk 2 |
08-16-2012, 05:54 PM | #11 |
08-16-2012, 06:19 PM | #12 |
The RX8 is a beast. It is Tekin's 1/8 scale buggy/truggy ESC and run's massive 2650kv T8 motors just fine, and lower kv's on up to 6s. 5amp 6v BEC and 210 amps continous. The downside is it's large. The RS Pro is the 1/10 scale ESC, meant for super low turn touring cars and such. Not really spec'd for 4 pole torque monsters. It also supports sensored only mode and timing "turbo" which isn't really used on crawlers. It has a 3amp 6v BEC. Both are fantastic ESC's. RS Pro is a little more expensive than the RX8. Think of the RS Pro as a Dodge Viper and the RX8 as a Dodge Ram. If you can fit the RX8 somewhere, it'll handle the load effortlessly. If space is a concern, the RS Pro should be able to handle the sheer current, but doesn't have the huge heat sink and thermal properties that the RX8 does. RX8 33mm H x 40mm W x 56mm L 2.7oz (to top of posts with fan shroud cut off) RS Pro 23mm H x 31mm W x 35mm L 2.3oz |
08-16-2012, 06:35 PM | #13 |
ok those the rs pro can handle the tekin pro4 3300kv ? and space is ok for rx8 my projet box il fit the esc and reciver is 112mm l x61mm w x 41mm h so both can fit easely ;) thx again for help |
08-16-2012, 06:46 PM | #14 |
You bet. With that much room, I'd definitely go with the RX8. Sent from my MB860 using Tapatalk 2 |
tekin rx8 or mmp - Similar Threads | ||||
Tekin RX8 vs Castle Creations MMP | XJkid93 | Electronics | 21 | 08-08-2012 09:59 PM |
MMP or Tekin rx8 with t8 motor | klabeaume | Electronics | 9 | 07-08-2011 02:14 PM |
Tekin T8 (truggy) 2000KV Which ESC, MMP or RX8 | Agama | Electronics | 12 | 06-06-2011 12:33 PM |
