08-19-2012, 07:03 PM | #1 |
Newbie Join Date: Nov 2011 Location: Toronto
| bec problem?
have a futaba 4pl r2104gf receiver ae2 esc 2 servos everything connected and everything works i added a castle bec pro pulled the power wire out of the esc servo connection plugged in the bec to the receiver in an open port now the receiver stays red when turned on, if i push the bind button it blinks red if i take out the bec from the receiver and put the power wire back in the esc cable it all works good again what could i be doing wrong? if all fails, i am thinking of running the dual outlets from the bec to the servos direct, and only leaving the signal channel plugged in to the reciever, but i dont think i should have to any help appreciated |
08-19-2012, 07:08 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: bec problem?
Could be over or under voltage what is your bec set to
08-19-2012, 07:13 PM | #3 |
| Re: BEC problem? |
08-19-2012, 07:24 PM | #4 |
| Re: bec problem?
it is set to 6v would that be too much? |
08-20-2012, 07:04 PM | #5 |
| Re: bec problem?
thanks for the help, set it to 5.2 volts and working fine!
bec problem? - Similar Threads | ||||
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
cc bec problem | DyrtyByrd | Electronics | 6 | 06-08-2010 11:00 AM |
Is there a problem with my cc bec? | jordi555 | Electronics | 6 | 09-01-2009 11:35 AM |
bec problem | cossack | Electronics | 12 | 05-19-2009 12:19 PM |
CC Bec problem | glondark | Electronics | 0 | 02-24-2008 11:46 AM |
