08-28-2012, 08:12 PM | #1 |
RCC Addict Join Date: Nov 2005 Location: Kansas
| FXR troubles... help!
First off, I'm running a single FXR, 3S Lipo, and a HS645. No BEC, no dig, no winch, nothing extra! A bit about my FXR: I bought it used, and added motor/battery leads. I run it inside of the Axial SCX-10 radio box (unsealed, with no attempt at waterproofing). While soldering on leads, I managed to burn through the clear part of the FXR decal (above the LEDs). I also shorted the on/off switch inside the box, close to the circuit board. My problem: Every time I plug in a battery and turn on my Tx, I get 3 flashing LEDs on the FXR. I've tried two different radios (both work, and both have new batteries). I recently made the switch to 3s Lipo, but I re-programmed the ESC via a Hotwire. I found the instructions to the FXR online, and under "troubleshooting" it says that a neutral signal cannot be found, and recommends re-calibrating the ESC to the radio. I did the re-calibration, and still nothing. After messing with the Tx's throttle trim, and finding a sweet spot, the ESC finally finishes it's setup and I hear the chime from the motor indicating that the radio has been found. So basically, at this point, every time I want to run my rig, I must re-calibrate my FXR. I'm not fond of doing this, Plug and play is what I'm after Let me know if you may have a suggestions, or if this has ever been heard of. Thanks in advance for any replies/help I receive -Greg |
08-30-2012, 12:16 PM | #2 |
| Re: FXR troubles... help!
So since I posted this thread I've tried: Different batteries (I tried my old NIMH packs), I've swapped between the 2 radios I have available to me, I've re-wired my truck, and I've re-positioned the wires (thinking that it could be an antenna interference problem) I think I've exhausted all options that I can think of. I've finally found a rig that I can enjoy and be proud of, and now this... maybe it's just time to drop some coin on a BRXL! I was kinda hoping to have this bug worked out before out G2G Saturday afternoon, but I may just give up |
08-30-2012, 12:25 PM | #3 |
Rock Crawler Join Date: May 2007 Location: Glendora
Not trying to tell you what to do or trying to be mean, but I would personally steer clear of buying used electronics unless you are sure of the source. I have learned this lesson myself years ago before getting into rock crawling. I bought used electronics from someone online, and it turned out the stuff was junk. If things do not get sorted out on your own, contact Tekin and ask them if they have non-warranty services available for their products.
08-30-2012, 12:39 PM | #4 |
RCC Addict Join Date: Jul 2009 Location: Near Boston
Get or borrow a Hotwire from a friend and make the Neutral Band (in the FXR) larger. It could be that the person you borrowed it from tightened this way up, for whatever reason. You may be able to adjust the neutral band without the hotwire by using the button setup. |
08-30-2012, 12:52 PM | #5 | ||
| Re: FXR troubles... help! Quote:
08-30-2012, 01:08 PM | #6 |
| Re: FXR troubles... help! |
08-30-2012, 02:01 PM | #7 |
Rock Crawler Join Date: May 2012 Location: Australia
I have similar issues with me fxr. But they wont calibrate. I brought them brand new. I'm now going away from fxrs and replace all the fxrs for something better. Good to here you got yours sorted. Dealing with tekin for warranty was always a PITA |
08-30-2012, 02:37 PM | #8 | |
Tekin worked worked with me to resolve a Hotwire issue with 2 RS ESCs, it turned out that my computer was at fault and killed both. Tekin replaced both within a week (shipping time). Their CS is excellent as is their warrantiy service. I only had to use it once in over ten years and for a user error that they fixed at no charge. I can't understand what your problem was. | |
08-30-2012, 02:43 PM | #9 |
I have nothing bad to say about any brand. I've been crawling for 7+ years and have ran everything from 30 dollar un-programmable esc's to high-end Castle and Tekin stuff... I've had a few problems along the way, but most were user error and/or resolved. My personal thought about ESC's is that people really need to do research before complaining about it... and that means myself too! |
08-30-2012, 02:54 PM | #10 | |
08-30-2012, 02:59 PM | #11 |
Thanks for that info too! I bumped it from 1 up to 100 maybe I should tone it down a notch... |
08-30-2012, 03:02 PM | #12 |
08-31-2012, 07:49 AM | #13 |
Wow, it was set to 1.... I can't imagine that is even usable. Maybe now you know why the other guy sold it. He probably changed that number without knowing what it means and could never get it to work again.
08-31-2012, 08:31 AM | #14 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Hey all you guys talking abut the neutral band, this is great information and now that I'm reading your experience on it's affects, I'm realizing it might also be the problem with my fxr also. The strange thing is I never changed anything in my fxr, it just one day would not arm completely... steering works, throttle flares up the led's but no motor response. Is this the same problem you were having grob (op)? Thanks |
08-31-2012, 08:41 AM | #15 | |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Adjust the NW will change the feel of the trigger too, the larger the number, the more dead space there will be around neutral, meaning the trigger has to move further to start moving the rig. If you like the trigger to be really sensitive and throttle to be applied with the smallest movements, start bumping the NW down lower until you start seeing the arming problem, then go back up until it stops. Last edited by Ty@Tekin; 08-31-2012 at 08:43 AM. | |
08-31-2012, 08:51 AM | #16 | |
Thanks Ty... I will definitely try this later after work before heading up to G-6 at the cantina event.. I hadn't seen anything posted about this in the other fxr threads on the same issue... but I'm going to say it makes the most sense since I really don't think there is anything wrong with my 3 y.o. fxr (original release v2 that's been flawless, but I'm running a gt3 radio so maybe that's part of the gremlin. thanks again | |
08-31-2012, 09:00 AM | #17 |
Ty, do you recommend using v31 over v28, or should I just leave it alone? Thanks |
08-31-2012, 10:01 AM | #18 | |
jcampbell@teamtekin.com Also I forgot, you will probably end up needing a BEC running 3S. If your servo starts stalling out or shutting your receiver down, adding one will cure the problem. | |
08-31-2012, 11:02 AM | #19 | ||
I have noticed that I need a BEC. I've been crawling for long enough to know when they should be used. Plus, when someone with a status such as yours recommends it, it's a no brainer! | ||
08-31-2012, 12:41 PM | #20 | ||
thank again ty.. Quote:
it's cheap insurance to run the bec either way. off to the G-6 guys thanks | ||
FXR troubles... help! - Similar Threads | ||||
E.s.c troubles | khsderek | Electronics | 2 | 01-15-2012 03:24 PM |
troubles w/ my subscription | BigSki | General Crawlers | 8 | 01-29-2010 05:50 PM |
Radio Troubles | Blazerbogger | Electronics | 4 | 08-27-2008 03:10 PM |
troubles | stanbro | Electronics | 3 | 09-01-2007 05:12 PM |
