09-01-2012, 10:08 PM | #1 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
| Tekin 13.5 no low end power? Help
Hey fellow crawlateers, I was hoping you could help me with a question. I have a fairly heavy wraith with a mmp and Tekin redline 13.5 brushless. She used to be fairly mean but lately it seems like she had less and less grunt when bound up in the rocks. Now on the last run on flat ground in the grass if starting from a dead stop I have to pop the throttle to take off. Top end seems ok but bottom is crappy. I figured I have killed my little 13.5 (sound bagpipes here). It does run warm but not crazy hot unless I just didn't catch it when it did! I'm running 12/60 32p gears. Thanks for the advice. Ohh by the way if the motor is going bad do you typically just replace the rotor in a brushless motor doing this? Thanks again |
09-02-2012, 10:00 AM | #2 |
It sounds like one of the windings in the stator are bad from binding it up. There is no reason to replace the rotor but the takins don't have replaceable stators like the novak ballistics so a new motor is likely in order Sent from my iPad using Tapatalk |
09-02-2012, 01:45 PM | #3 |
| Re: Tekin 13.5 no low end power? Help
Can you check that with a dmm, using an ohms test?
09-02-2012, 03:43 PM | #4 |
Newbie Join Date: Aug 2011 Location: Indy
You can not test with a dmm. The meter will show continuity in all directions. If you can see the windings look for one that has been hot(discolored).
09-02-2012, 05:10 PM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: Honolulu
My 13.5 Tekin is the exact same. I will take mine apart and see if there is a discolored wind.
09-02-2012, 05:32 PM | #6 |
Check your sensor cable
09-02-2012, 05:35 PM | #7 |
| Re: Tekin 13.5 no low end power? Help |
09-03-2012, 07:31 AM | #8 |
Could be a demagged rotor. That is the one problem with the smaller roar style motors, if you bind it up and go too far on the throttle it can degauss the rotor. First I say look for discoloration on the winds, then you should have the rotor strength checked. If the winds burnt up you need a new rotor anyway.
09-03-2012, 08:33 AM | #9 |
Is it worth New windings and rotor if needed or just buy new motor?
09-03-2012, 11:29 AM | #10 |
With a takin motor you are going to get a new motor as only the rotor would be easily replaceable Sent from my iPad using Tapatalk |
09-04-2012, 08:30 AM | #11 |
Pebble Pounder Join Date: Aug 2011 Location: San Antonio TX
I had the same motor in my wraith. I ended up damaging the motor. Mine is heavy as well. I sent it to tekin and the fixed it. then I bought a pro4 3300KV. Night and day power
12-22-2012, 10:15 AM | #12 |
I bought the pro 4 cause I have no patience. I am sold on 4pole motors. Me like torque I sold the redline to a bud and he sent it to Tekin and they warrantied the rotor. I magnet had bit the dust. Thanks Tekin for the pro4, I love it and my buddy I'm sure will love the 13.5. |
Tags |
13.5, brushless, no power, takeoff, tekin |
Tekin 13.5 no low end power? Help - Similar Threads | ||||
Is the Tekin B1R "low power in reverse" issue fixed? | GWEEDZ | Electronics | 3 | 05-27-2011 12:50 PM |
New MMP 1c and some low end cogging | concretejungle | Electronics | 31 | 02-27-2011 09:47 AM |
jerky motor in low end | matador88 | Electronics | 2 | 05-13-2010 06:39 PM |
