09-02-2012, 08:42 AM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: St.Louis
| Using laptop fans as a cooling mod?
I have 3 fans from old laptops and a desktop all are less than 3 inch So who has tried it and do the fans need to be volt specific to be able to run on a typical reciever port? I have plenty of old servo plugs to rewire these. They are three wire but one is 4 so not sure on that one so it might go in trash cause I think that's a different voltage? Like to see pics advise and wiring if possible Thanks art |
09-02-2012, 09:21 AM | #2 |
| Re: Using laptop fans as a cooling mod?
Yes, they need to run at whatever voltage is going into the RX (likely ~5 volts if off the ESC red wire, may be 7+ volts if an external BEC is running into the RX). Some are AC, not DC powered (not very likely). I would start by looking up the part number on the fan and see if you can find a spec on it. For all this, an actual "RC related fan" would be better. |
09-02-2012, 09:32 AM | #3 |
True but free is better lol!
09-02-2012, 09:58 AM | #4 |
| Re: Using laptop fans as a cooling mod? |
09-02-2012, 12:46 PM | #5 |
Yeah well all the fans are dead lol I guess it's meant to be. I think I will buy some cheap fans from hobbyking... Atleast they ate plug and play |
09-02-2012, 09:01 PM | #6 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Ive used one before. I built a fan controller for it using a thermister wrapped around the motor. So the hotter the motor got the faster the fan would run. It just plugged in the RX.
09-03-2012, 09:38 AM | #7 |
I running a laptop fan in my 1/6th scale Jeep to keep things cool, I just plugged it straight into an empty Rx port.
Using laptop fans as a cooling mod? - Similar Threads | ||||
Cooling fan | Dukiball | Team Losi Comp Crawler | 5 | 04-07-2010 07:15 PM |
Are cooling fans needed? | Dollarhide | Electronics | 1 | 06-22-2008 08:16 AM |
EVX Cooling | thorn4run | Electronics | 6 | 10-12-2006 07:46 PM |
Nitro Cooling | Fordtrucks | Traxxas Crawlers | 16 | 05-08-2006 10:48 PM |
Motor cooling | mt_power | Electronics | 11 | 05-03-2006 01:28 PM |
