09-07-2012, 02:10 AM | #1 |
Rock Stacker Join Date: Feb 2012 Location: Israel
| Radio/Receiver Question
Hi, I'm planing on building a new truck, but I need some help with the electronics. Right now, I'm controlling a 2 channel receive with a basic 2 channel radio transmitter. But in my new project I want to integrate a 2 speeds gearbox, that change will need a (at least) 3 channel receiver and radio. I own an E-Sky 4 channel transmitter, but not a receiver. Can you please suggest me a good receiver to work with the E-Sky transmitter? P.s. Do receivers come with crystals? Thanks! yoraish |
09-07-2012, 02:14 AM | #2 |
| Re: Radio/Receiver Question
Well, in addition to my last post, the E-Sky transmitter is a 72MHz unit, will it be good to run a truck?
09-07-2012, 04:42 AM | #3 |
No reason you couldn't use a 72mhz radio, just make sure you keep the RX away from the ESC & motor to limit interference. RX's usually DON'T come with crystals, you have to buy them seperate. Some radios require that you run a RX from the same company as the TX, you may not be able to run a HiTec RX with a E-sky TX. |
09-07-2012, 05:14 AM | #4 |
That makes sense, thanks a lot!! |
09-07-2012, 08:58 AM | #5 | |
| Re: Radio/Receiver Question Quote:
Well, if you don't fear the FCC, and have no regard for any model airplane fliers in the area, then go for it. 27 & 75 mHz are frequencies approved for ground use only. (cars, trucks, boats, tanks, battlebots, etc) 72 mHz is approved for air use only. (planes, helicopters, gliders, dirigibles, etc.) EDIT: My bad, the above info is for U.S. regs. just checked your location and where you are, they might not have such laws, I don't know. But mechanically, it'll work. Been a long time since I bought a receiver on those frequencies, but iirc they didn't come with crystals. I usually reused old ones, or just bought a new set if I was adding a vehicle to the fleet. Last edited by Trubble; 09-07-2012 at 09:02 AM. | |
09-07-2012, 10:01 AM | #6 |
That's very interesting! I never thought about such thing. There is just one thing I don't fully understand: Is a 72MHz transmitter "weaker" than a 2.4 GHz transmitter? Or the frequencies are there for another reason? |
09-07-2012, 11:55 AM | #7 |
Newbie Join Date: Feb 2011 Location: Adrian
| Re: Radio/Receiver Question |
09-07-2012, 06:44 PM | #8 | |
Other benefits are that 2.4ghz tends to allow multiple "models" on a single TX. You turn on the TX, pick the rig you want to run, turn on the rig & off you go. With AM or FM, you usually needed to tweak settings when running a different rig off the same TX. Close, but not perfect. For the money, a hacked GT3B or GT3C from LosiKid/OverkillRC is a way to go. It's 2.4ghz, hacked complete with a RX is less than $100, additional RX's are $10 or less. | |
09-08-2012, 02:59 AM | #9 | ||
| Re: Radio/Receiver Question Quote: Quote:
Thanks everyone | ||
Radio/Receiver Question - Similar Threads | ||||
HPI TF40 ghz radio and receiver question | bro_die | Electronics | 2 | 08-15-2012 07:28 AM |
need a receiver and radio... | sierradmax | Newbie General | 1 | 01-27-2008 03:28 PM |
please help! question about radio and receiver! | rockbound | Electronics | 4 | 08-29-2007 05:18 PM |
