09-07-2012, 05:15 PM | #1 |
Pebble Pounder Join Date: Sep 2010 Location: West Linn
| Castle Maxx ESC Issues
Hey guys, just installed a castle maxx esc with the external fan on it and ive ran it 3 times crawling and now when I plug my battery in, all it does is make the connection sound when it starts up, and it repeats it over and over. Cant move it, or steer. Could it be the ESC causing this or a receiver? I sure hope its not the esc, sucker was expensive lol Any help would be appreciated. Heres where it clunked on me. Nothing extreme |
09-07-2012, 05:47 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: Castle Maxx ESC Issues
Sounds like a dead battery
09-07-2012, 08:28 PM | #3 |
Is it just beeping repeatedly? If that's the case it's not receiving signal from your tx/rx. Check the rx plug and make sure all the pins are in and making connection with the rx. If not making a complete connection your rx will not have any power (if you are not using and external bec) so you wont have steering either like you are experiencing. Sent from my iPad using Tapatalk |
09-07-2012, 09:07 PM | #4 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Check your trims to make sure you didnt bump them. Recalibrate the radio and esc if needed. Does the radio have multiple models ? are you on the right one if it does ?
09-08-2012, 08:31 AM | #5 | |
| Re: Castle Maxx ESC Issues I just charged my battery, but i could try my brothers to see if mine clunked. Its a brand new, only used for two or three trips Quote:
Ill try that too, i dont think i bumped them. Sometimes it is something really simple like that, start easy i guess. | |
09-08-2012, 08:33 AM | #6 |
By the way I have a DX2e spektrum setup, its just a 3 slotted receiver. Aux, throttle, steering
09-08-2012, 08:36 AM | #7 |
TX = transmitter RX = receiver Make sure the plug from the ESC is firmly in the channel 2 port on the RX. This plug is what powers the RX & the steering servo. |
09-08-2012, 08:52 AM | #8 |
Since you are using a bec, check and see if the becs green light is on. I suspect your bec gave out. To test it put the red wire from the mambas receiver plug back in so it powers the everything instead of the external bec. Sent from my iPad using Tapatalk |
09-08-2012, 10:18 AM | #9 |
| Re: Castle Maxx ESC Issues Everything is snug, I got it to connect to the controller, I just reset it. Now the rig moves forward and back just fine, but the steering is WAY underpowered. The BEC light is on, and everything is connected again. Something strange is going on, usually I could jam the tire pretty good and it would atleast try to turn it full lock to lock. Now it wont even steer on its own 4 feet, it will turn lock to lock when its in the air, seems weak.
09-08-2012, 10:22 AM | #10 |
Snapped a couple pictures of my birds nest w/ zipties. Originally was in a water balloon, thats why its all so tight haha. All lights are good to go though |
09-08-2012, 11:12 AM | #11 |
| Re: Castle Maxx ESC Issues +1, it looks like you have the older CC BEC, they can "just die" at times. |
09-08-2012, 12:13 PM | #12 |
| Re: Castle Maxx ESC Issues |
09-08-2012, 12:25 PM | #13 |
09-08-2012, 01:19 PM | #14 |
I dont have a reader for detecting voltage, but I just unplugged the BEC from the receiver and its doing the same thing. So its acting like its not working? Maybe a new BEC is the cure? Also if this makes any difference, I plugged the BEC into the aux port, and the throttle port I have all 3 wires from the ESC still in place. I was looking at the diagram for BEC wiring and they said to remove the red wire from the ESC line to the receiver, so i did that and the car wouldnt move at all or turn on. So, I reconnected the red wire and it worked fine until this happened. Would you know why the red wire screwed things up when its originally supposed to be disconnected?
09-08-2012, 01:45 PM | #15 | |
| Re: Castle Maxx ESC Issues Quote:
Usually, when they fight, eventually one will win & the other will die. (there are some engineers on this forum that will say this is safe to do......you have proved it's not.......) Your "test" is showing the external BEC is likely dead, thus nothing happens when you remove the red ESC wire and only have the BEC plugged in. Castle users guide....(covers ESC calibration) http://www.castlecreations.com/suppo...s_ed_guide.pdf Castle ESC FAQ's..... Castle Creations | FAQ: 1/10th Scale Products Trouble shooting is near the bottom..... | |
09-08-2012, 05:11 PM | #16 |
Ok so I went to my LHS and they tested the ESC and BEC and both checked out fine. They disconnected the red wire, but later found out that my servo was the issue. So, I replaced it with a Savox SC-1268. Plugged it all in and it works great. Servo is really noisy but other than that its decently powered. Thanks for all the help guys, got me off my feet to fix it lol
09-08-2012, 06:26 PM | #17 |
Sounds like you have a decent LHS.....buy stuff from them when you can!! From your description, I never thought of having you disconnect the servo. Sorry, my bad. Glad you have it resolved. |
09-09-2012, 08:30 AM | #18 | |
Thanks for your help though! | |
Castle Maxx ESC Issues - Similar Threads | ||||
Castle link issues | TXJeeper1 | Electronics | 11 | 09-20-2011 06:28 AM |
Castle Link issues | badyj | Electronics | 1 | 05-15-2007 07:59 PM |
