09-09-2012, 06:37 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: canada
| Fxr help me please
im at a loss i went out crawling today and went to bring my ax10 out for some fun i apparently had a lipo short and burn up the Capaciter so currently there is no CAP on the esc not sure if this is the reason why but this is what she does truck spec tekin fxr 50T brood spectrum dx3E also tried my futaba 4pl when i give it forward Throttle it goes wide open no matter how much or little i pull the trigger. when i go revese its even weirder slight reverse is WOT and the more i pull the trigger its like its ramping down and giving Less throttle once the trigger is actually pulled in reverse all the way its like That is the brake. i do have a hot wire and have programmed it the same as a few people i searched on here any Help PLEASE i can use it as i was going to use this rig as my truck of choice for a 1st time KOH we are going to be running a week from today HELP PLEASE |
09-09-2012, 07:07 PM | #2 |
| Re: Fxr help me please |
09-09-2012, 07:32 PM | #3 |
alrighty thanks looks like i need to find out if any of my LHS have them.
09-09-2012, 07:45 PM | #4 |
ordered some caps. i guess easiest way to describe it.. typically it would be forward / brake / reverse mine is forward / reverse / brake does anyone know if this is due to the cap?
09-10-2012, 01:00 PM | #5 | |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
| Re: Fxr help me please Quote:
That being said I ran for a short amount of time with the leads broken to a cap on my Tekin RS and it acted erratic until I re-soldered it. There may be hope. Leave it off until the cap is replaced and them fire it up and recalibrate it. | |
09-11-2012, 10:09 AM | #6 |
new cap soldered on. esc is still doing the same wonky stuff forward is wide open even with just slightly touching the trigger. reverse is even weirder it does not change the direction of the motor it goes the same direction as when pulling the forward trigger. and it ramps down. so slightly touching revers is actually WOT reverse and fully pulling the reverse trigger slows the truck down to brake. any help would be appriciated as i cant afford to buy a new esc rite now and i need this rig running for a KOH were holding locally this sunday specs of whats being used dx3E sr300 rx cc bec 3s 800mah lipo tried a 20t hh a 40t brood and my know good test motor 55T axial thanks in advance for any advice |
09-11-2012, 10:35 AM | #7 |
Have you tried recalibrating to your radio?
09-11-2012, 11:34 AM | #8 |
yes numerous times sometimes it finds neutral some times it doesnt but ive done it maybe 10 times and no fix. even tried another sr300 and dx3e and even my 4pl futaba still all work out the same.
09-11-2012, 12:35 PM | #9 |
Hmm, only other possibility I see is the cap polarity. Other than that a faulty esc, unless someone else has any ideas.
09-11-2012, 01:36 PM | #10 | |
Why not try the 4PL again to rule out a failing trigger on the Spektrum now that the cap is replaced. Remember to calibrate the ESC to the new RX. | |
09-12-2012, 08:33 AM | #11 |
ive tried the 4pl 2 dx3e's and even a stock wraith radio all do the same thing but all work perfect on other esc's
09-12-2012, 08:49 AM | #12 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
When you calibrate, are you setting all epa's to 0?
09-12-2012, 09:06 AM | #13 |
09-12-2012, 09:23 AM | #14 |
all trims are at 0 and all EPAs are wide open on both my 4pl and dx3e still acting stupid what gets me is no matter what i do forward or reverse it still only turns in one direction
09-12-2012, 10:13 AM | #15 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Have you Factory Reset the ESC? Try that, then recalibrate. If it's still not working right then that shorted LiPo may have damaged it.
09-12-2012, 11:15 AM | #16 |
whats the easiest way to rested the frx? as the paper work i have states how to do a self test but doesnt say how to reset it. and im hoping its just goofy and not damaged or il be screwed for this weekend lol. Last edited by Pegasix; 09-12-2012 at 11:18 AM. |
09-12-2012, 01:13 PM | #17 |
That would be it Charlie, I was on the right track just backwards...
09-12-2012, 01:43 PM | #18 |
| Re: Fxr help me please Press and hold both buttons and it will chime 4 times with the LEDs climbing up the bar. Once it does that, let go and then recalibrate it.
09-12-2012, 01:55 PM | #19 |
09-12-2012, 01:57 PM | #20 | |
Not complaining, just asking since we have a few Tekin ESC's in our house. | |
Fxr help me please - Similar Threads | ||||
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
