09-27-2012, 08:23 PM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
| timing adjustment?
Is the timing adjustable on the Tekin t series motors! I just put two on an XR10 and the front wheels spin faster than the back wheels in forward and the back wheels spin faster in reverse! The set up us two micro sidewinders, bec and a 4pl radio. I have already set up the dual esc setting on the radio so that is good! Any suggestions would be appreciated.
09-27-2012, 08:31 PM | #2 |
| Re: timing adjustment?
Should be, loosen (not remove) the two screws on the back of the endbell and rotate it. Spin in the direction of rotation for advancing, you are looking for 4-8* advanced on both motors.
09-27-2012, 10:12 PM | #3 |
Rock Crawler Join Date: Mar 2010 Location: Hampton
Mine did the same thing when I put in some spare esc's. I just recalibrated the esc's to the receiver and it fixed the problem. It actually took me a while to get this one figured out.
09-28-2012, 01:26 AM | #4 | |
| Re: timing adjustment? Quote:
Spin the endbell AGAINST the "normal motor rotation" to advance the timing. I agree with Grimreeper.....try calibrating the 2 ESC's 1st if it worked OK before. Make sure both ESC's have the same version firmware in them. I like to make a profile for a ESC, save it, then load into the 2nd ESC. | |
09-28-2012, 08:42 PM | #5 |
Not exactly sure what I did to fix my problem but everything is working normally now! Possibly when I re calibrated the rear esc and the changed a few settings in the radio! Now I just need to figure out how I am going to stuff everything in there so it doesn't look like a rats nest LOL.
09-28-2012, 10:21 PM | #6 | |
09-29-2012, 08:27 AM | #7 |
| Re: timing adjustment? |
09-29-2012, 08:48 PM | #8 |
as long as they werent fords. I think i remember them going backwards. or the other way which ever you prefer working on.
09-30-2012, 06:31 AM | #9 |
| Re: timing adjustment? I was not referring to CW or CCW rotation, more of the, "remove the distributor cap, crank engine, see which way the rotor rotates, determine which way to twist housing to advance or retard ignition timing". |
timing adjustment? - Similar Threads | ||||
C-hub adjustment? | davidq19 | Axial Wraith | 2 | 01-06-2012 03:29 PM |
Tranny adjustment help? | ThumperK15 | Electronics | 2 | 12-27-2011 07:08 PM |
slipper adjustment | redbones | Axial Wraith | 2 | 10-08-2011 11:14 PM |
Remote adjustment? | GrumpyTX | Redcat Crawlers | 4 | 05-17-2011 08:17 AM |
Endpoint Adjustment for ax-10 | chartrunner | Electronics | 1 | 05-24-2010 07:16 PM |
